Phone: Turn on Bluetooth and Bluetooth visibility. Keep it close to the headset (20 cm).2. Headset: Switch it off. Press and hold down the on/off key until the pairing icon appears on the display.3. Phone: If your phone supports auto pairing, press YES when Add device? appears to complete the procedure. If not, continue with the next step.4. Phone: Follow the applicable User guide to pair with a Bluetooth headset. You may need to enter a headset passcode (0000).
For connecting to other devices, press & hold the power button of your bluetooth headset for initiating the discoverable mode. When the led light starts flashing in red color, search for the headset from the phone in which you wanna connect. Open the Bluetooth settings, turn it on and search for new devices and pick from the list and pair the headset. After this, the headset will be auto-connected.
I have the same problem, did some research and found the blueant homepage. Unfortunately the Nokia N97 is not compatible with the blueant ... the N95 and N96 is but not the N97 .. SUX ...here's a link to their homepage so you can check it out yourself ...http://www.blueant.com.au/index.php
Be sure the the headset in in 'Pairing' mode. When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
