If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Hi not heat but warm battery during charging is normal...but if discharges rapidly your battery may have reached the end of life..before buying a new battery pls make sure that your charger is ok...you can test it with another nokia with same charging plug..all the same on Nokia.. Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
HI there,Unlock your phone just by inputting a code using the phone's keypad. You need to generate the unlock code for your phone's IMEI/serial number. NOKIA 5130c2 Unlock Code offer you to unlock your Nokia 5130c-2 phone to enable use of your phone with other network carriers without any restrictions, saving money by avoiding roaming charges and increasing the value of your cell phone. Hope this is helpful. Thanks.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Hello my name is Ibrahim Makki and might help you maybe your battary date has expired or you had put the battarey on charge for long time so it blow or leave it for long time , try to buy a new one
show charging but not charg battray
