Question about Kalinka Baigish 12 Russian Night Vision Binoculars
Have a camo binoc that only markings are CHINA and NIGHT VISION...but cant find battery placement....might not truely be night vison?
Posted by deanlucabaug on
Richard Morris
    Master:
  • 577 Answers
Hello, Kalinka Baigish is Russian and they do make NV devises but China? Now, the Chinese do manufacture NV Image Intensfier tubes to Generation 2 but manufacture the hole night vision devise is new to me. Of course, about 1/3 of the world countries manufacture some sort of night vision devises or there parts.
Contact Night Vision Optics they sell these Russian night vision devise under the brand name: Night Vision Optic and they have a logo. There are only companies in the US that manufacture night vision stuff. Also, some of the US companies do use US image tubes and other electronic components, and maybe US optics are used. GB...stewbison
Posted on Sep 07, 2011
How and where do i remove the battery
Note where he points to place the battery at 3:49 minute mark
Night Owl Optics Night Vision
requires (1) 3-volt Type-123 lithium battery (not Included)
Apr 15, 2016 | Night Owl Optics Night Owl NONEXGEN-W...
Where can i find a BAIGISH Sakura 10-70X50mm Night Vision Binoculars Scope user guide/manual online?
Dino Direct carries them and has a pretty good description for them but is not complete. If they opearte in the manner I think they do, hold down on the lever to power them- do not pump, just press and hold. Since there is no mention of a battery or cell, this is the usual alternate method to power them.
Otherwise the online information that is most complete is http://www.dinodirect.com/sakura-scope-10-70x50mm-binoculars-night-vision.html
Jan 12, 2012 | Optics
I have acquired a night owl monocular nightscope. the only number I could find was in the battery compartment # H3T-3M. there was a serial # 9846786. The problem appears to be the switch. the powerligt...
Yes, If you turned the Night Owl on during the daylight hours, or looking directly into bright lights.
If you have done this more than few time it could have damaged the image intensifier tube. If this happen to many times, it's finny, kaput, so long, it gone south, and gone bye-bye.
Looking at bright lights is damaging to NV devise. The intensity plate in the image tube, magify the existing light about 3000 to 8000 (radian light from the stars, moon and other light sources).
You have 80mm front lens on the Night Owl NOCP5. This mean that more light can inter into image tube.
Sir, have you been looking at bright lights, operate NV system during the day, have you? If not, there could be something else worng with you Night Owl. stewbison
Mar 07, 2011 | Night Owl Optics Cyclops Pro NOCP5...
My problem is that i have a Night Vision Binocular Rigel 2100 and i Cannot see nothing thru them is all black
Hello, did you install new batteries? Is the battery compartment terminerals clean? stewbison
Jan 21, 2011 | Night Owl Optics Rigel 2100 Pro Night...
What kind of batteries do i use and where do the batteries go?
Hello David. David you night vision doesn't use any batteries that one installs. You have Kalinka Zenit NV monocular that is Russian manufactured but is sold by Night Vision Optics. Your night vision uses a piezo electric ignitor to charges the batteries and charge a couple capacitors.
The lever on top to the Zenit monocular is activated by squeezing the handle that is covered in a rubber type material. Just keep squeezing on the lever and in while things will start working. Best of Luck David. GB...stewbison
Nov 11, 2010 | Kalinka Zenit NV Piezo Russian Night...
I have a pair of atn night cougars and i havnt used them in a year and they needed new batterys so i got some. when i put them in they wont turn on and i cant figure out what the problem is.
if you left the batterys in and stored the night vision for a year the batterys could leak,,,look at the battery contacts inside your units if corroded clean them up they should work then
never leave baterys in the unit if storing it away for more than a month
Aug 15, 2010 | Optics
My intex night visons cam show black screen only i have installed drivers
my intex night vision cam show black screen only i have installed drivers
Feb 14, 2010 | Ezonics EZCam III Webcam
How do I replace the battery on Baigish 12 night vision binocs?
Go to; www.rugift.com. They are a dealer for this NV and they do have the user manuals.
Good luck. :)
Mar 11, 2009 | Kalinka Baigish 12 Russian Night Vision...
How can I clean the inside of the objective lens on my night owl optics night vision?
front lens unscrews to check front of tube but if it is a black mark on screen then it is an internal tube phospher fault and cant be removed this is the case when you have cleaned front of image tube and screen of image and see no visibl marks
wayne
Apr 22, 2008 | Night Owl Optics Explorer NOCX3G Monocular
Kalinka Baigish 12 Russian Night Vision Binoculars Logo
324 people viewed this question
Top Kalinka Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Kalinka Optic Expert? Answer questions, earn points and help others
