Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
A
Anonymous Posted on Jan 09, 2011
I have a Sony Trinitron 32 inch TV...and the "Initial Setup" box keeps popping up on the screen. I am hearing different opinions and not sure what to do. Can you help? Thanks...
5 Related Answers
Anonymous
  • 232 Answers
  • Posted on Dec 12, 2007
SOURCE: sony trinitron 32
Hi, tubes getting tired, band-aid fix you can do is remove back of set and turn up(clockwise) the screen control( small black plastic control mounted on side of flyback transformer, do not turn the knob marked focus) until you see a whole bunch of white lines across the screen, then turn same control counter-clockwise until all the lines go away, try several different channels to be sure all the retrace lines are gone, you`ll get up to 1 year more use out of it, than she`s done, good luck, BMW Rider
coyotedave
  • 280 Answers
  • Posted on Apr 18, 2008
SOURCE: Sony Trinitron 32"
Turn off the closed caption
Angelola
  • 4 Answers
  • Posted on May 07, 2008
SOURCE: picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Anonymous
  • Posted on May 25, 2008
SOURCE: Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
zavalnitchi cornel
  • 40 Answers
  • Posted on Jul 10, 2008
SOURCE: sony tv keeps turning off
first make sure that the plug of the tv-device is well pluged-in and the voltage in your home is normal.if all this, is ok ,enter in the menu and check the status of `timer sleep`(if `on `than turn it `off`)
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
The "Initial Setup" screen pops up and starts
replace your tac switches maybe one of the switch are defective.
2helpful
3answers
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
3helpful
My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Initial setup
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
2answers
Initial setup
First give it a hard reset. To do this you must unplug the power cord for at least 4 hours; then try again.  This will reset the internal programming and restore it to factory defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not solve the problem it has a defective eeprom OR a bad voltage regulator that feeds the controller IC/eeprom set.  In which case you will need a tv tech to dignose the exact fault and determine the defective parts. (There are over 100 parts associated with these functions).
Hope this helps.
2answers
Sony 32" wega tube
plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
1helpful
2answers
Initial Setup flashing on and off
Heh. I just gave my set the "Fonzie treatment" after I was convinced the initial setup notice was messing with me. The problem cleared right up. No joke.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
