SOURCE: Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
I had the same issue after trying to update firmware the PC kept saying the player was not connected, I have copied the reply below from Creative Customer Services on how I fixed this problem. I was lucky that I have access to an old PC that had WMP 10 so I didn't need to mess with my own PC. However, there was some messing about with the instructions to get the fix. My main tip is follow the instructions below, then go to device manager and uninstall the Zen from your USB list, it will probably be flagged with a yellow triangle. Remove it totally and then reinstall the Zen driver, this worked for me after I had taken the steps listed here;
1. Please uninstall all Creative software & Drivers.
2. If WMP 11 is installed, remove it including Media Player 11 runtime
(may require a reboot for each thing).
Go to add/remove programs and uninstall these two files (this will put
your pc back to wmp10). http://support.creative.com/kb/ShowArticle.aspx?sid=16737
Related topic is further explained on this page http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#DevicenotrecognizedafterinstallingWindowsMediaPlay
3. Download the following files from the website and save them to a
unique folder.
http://support.creative.com/welcome.aspx
You may have to select your own Product > Choose your Specific Model>
then Double Click.
Down below; please ensure that your Operating System selected is Windows XP.
Driver : Creative Zen and Jukebox Driver Upgrade version 1.30.03
Firmware: Creative Zen Touch PlaysForSure Firmware 2.11.01
You may want to click the Show Details button on the right side for
additional information.
4. Re-install the Zen Driver and reboot the PC and then connect the
player.
5. Make sure the firmware update is ready,
Run the program but don't click the language bit yet), leave the mouse
hovering over your language selection.
6. On the Zen - select the option "reload OS"
7. As soon as it flashes up "reload new firmware now via USB" click the
language button on the firmware.
8. Now PC should find it and allow you to re-load the firmware. (it may
take a few attempts)
9. Once complete, click close and restart the pc. Everything should now
be fine.
10. If installation is successful, you can re-install your WMP11 and
everything should be okay this time.
Good luck
SOURCE: creative zen
On the side there is a small hole, if you use a paper clip and press it in the hole for a few seconds the player will be reset. You will feel that you are pressing the reset button. My doughter had the same problem, dead to 100% but after reset it worked again.
SOURCE: i have a broken creative zen x-fi 8 gb screen
have you check the main deeler to try and get a replacement screen?
