My Dewalt 12.5 inch planer skips or bits in approximately every 6 to 8 inches while planing. The belt is new the blades are new, the bushings are good and the feed rollers are clean and in good shape. Do have any ideas what to check next? Thank you. Mike
The Woodfordtooling is online shop for all types blades planer blades , tersa knives , bandsaw blades and other woodworking tools at UK And all over world
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
Use a backing board, such as high grade 3/4 inch plywood under the board you are planing, and you should be able to get down to 1/16, depending on the stability of the board you are planing. Take light cuts and flip it over to cut on both sides. Sounds like you might be making a guitar?
Good luck.
