Check the outlet to ensure it :1- has power , 2- is not a switched outlet. Check your wire connections to ensure they are secure. If all of the above are good, the transformer may have shorted when disconnecting. Use a voltage meter on the transformer terminals and the AC scale, check the output of the transformer.
SOURCE: Simon 3 "System Low Battery" after 3 years use
I install these panels. For the low battery message to clear you need to power the system down completely. To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet. When you power the system back up, you need to first plug in the battery leads. Then the transformer.
SOURCE: GE Simon XT panel lights window, door and motion indicators
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
SOURCE: GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
