Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Why does my washer stink like rotten eggs? When I remove the fabric softener cup, it is covered with brown gunk! How can I get this clean?
Posted by preedys on
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: Fabric Softener won't dispense
Suggestion: Possible your inlets to the machine is blocked. Check out the inlet tubes to clear out any blockages. This shd be done after the machine is off and the inlet valve is turned off. Some softeners are thick; you can add warm water 1:1, but this is not the thing in your case....
Posted on May 28, 2007
Anonymous
SOURCE: Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Posted on Aug 05, 2007
Joe Hogan
  • 10865 Answers
SOURCE: Fabric softener cup on Maytag Neptune washer is
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Posted on Jul 14, 2009
Anonymous
  • 64 Answers
SOURCE: the washer stinks. we leave door open. when you
Try washing without a load in it with a cup of bleach.
Posted on Aug 08, 2009
FAV6800AWDIY
FAV6800A FAV9800A
  • 526 Answers
SOURCE: my maytag neptune TL fabric softener cup seems to
If your machine is a FAV6800AW/FAV9800AW see if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove gunk build up.
If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue.
The Service Manual for reference use and care guide has some info
Rich
Posted on Nov 01, 2009
Rotten egg odor inside washing machine when not in use. Want smell to stop.
Try running a cycle with a few cups of bleach. Or a few cups of vinegar. Let it set for a while. Should help
Oct 07, 2015 | Washing Machines
Washing machine smelling
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash. Actually you can search by clicking on "ask anything" indicating your problem, this site.
Click helped if really helped.
Apr 09, 2013 | Whirlpool Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
We have a pin trap problem. The outer cover comes off exposing a plastic white facing that will not budge. There is constantly a rotten egg smell coming form the washing machine. I've drained the hose...
Here's How:
  1. Exterior
    Wipe down the exterior of the washing machine with vinegar or your favorite all-purpose cleaner.
  2. Tub
    Pour two cups of vinegar or lemon juice into the tub, and run the washing machine through a complete cycle on the hottest setting to remove odors, stains and detergent build up.
  3. Lid/Door
    Scrub around the edge of the lid/door with vinegar to remove mildew and detergent build up.
  4. Bleach and Fabric Softener Dispensers
    Remove the bleach and fabric softener dispensers, and scrub them in the sink. Then, dry them thoroughly and return them to the machine.
Tips:
  1. To prevent mildewing, leave the lid open after you finish a load to allow the washing machine to dry out.
  2. Commerical fabric softeners leave build up in the machine. of choice, and the inside of your washing machine won't need to be cleaned as frequently - if at all.
May 17, 2011 | Asko W6021 Front Load Washer
Dishwasher is leaving gritty material in bottom
Hi
Thanks for using FixYa. You’ll need to check down the edge of the door seal, see if there is a lot of "gunk" there, this would cause grey marks on laundry. Try these steps--
You'll have to do a few maintenance washes to clear it out of the tub. Try these steps to remove the dirt, debris and odor from the washer—
  1. Set your machine to 60 degree wash.
  2. Now add 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it.
  3. Your drain will sparkle, and it will remove all the debris, lint & mold growth from the drain pump and drain filter. Also the mold from the door seal will be cleared
  4. Add 1 desert spoonful of Washing Soda to every wash... I sprinkle it along the crease in the door seal.
  5. Clean the fabric softener cup with a rag first, (bleach will not break up fabric softener as it is introduced in the rinse cycle with the fabric softener.
  6. Also check the drain hose, it should not be clogged.
This will clean your machine and get rid of the gritty material in the bottom.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Jul 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
