Question about LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor, on screen
Posted by djukicr on
Chandrashekhar N.G
  • 615 Answers
Dear Sir,
This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
Posted on Jan 08, 2011
LG 700e crt monitor is showing all in rainbows!!!!
Remove any speakers or magnets that you might have near the monitor as they can cause visual distortion on your monitor screen.
Mar 05, 2014 | LG Studioworks 700S 17" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My lg 17inch CRT flatron E700SH monitor is blinking light but it not given display
Did you check to make sure the PC is sending a video signal? Try another screen to confirm if possible...
Oct 22, 2010 | LG Studioworks 700S 17" CRT Monitor
My monitor model.No 700E i Start My Moniter showing Yelow Screen
You could have a bad cathode ray tube or you have a bent pin on the VGA cable.
this could also be due to a color correction circuit on the monitor circuit board.
Your monitor may also have succumbed to age.
Jan 29, 2010 | LG Studioworks 700S 17" CRT Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Want to connect game on laptop
vga uses separate rgb (red, green, blue) connections to compose a video signal, sync and resolution, whereas the video female uses an analog signal with different signal info. you need to get a tv out adapter for your pc that cames with a the display hardware. look for video cards with video out or if you have a digital tv, with hdmi or dvi out. good luck
May 20, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Wnts t know how to open it
if you can't figure it out, don't do it.
you will kill yourself from electrocution.
Sep 09, 2008 | LG Studioworks 700S 17" CRT Monitor
LG StudioWorks 700s Monitor NO SIGNAL
First of all I would check your video card. Do you have another monitor that works fine? If so I would hook the good monitor to your video card and see if you are getting a signal. If you still do not have a signal in the good monitor there is something wrong with your connection on your video card. Check the connector on your video card if it wiggles alot then it has come loose from the card. Best option here is to buy a new video card. If you feel that the connector is seated flush and does not move. Then you might want to look at two things. Either your monitor is not working properly or there maybe a piece of hardware that has come loose or unseated in your computer case. Try this and if you have problems feel free to contact me.
Sep 20, 2007 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
195 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
