Question about Reddy Heater-30-55,000 BTU Variable
S/n#zg080481b mod#blp42a, rlp40, spc-40a all these are listed on the heater. fan runs fine, when i ignite and hold the primer button in (not really sure if it is called the primer) the unit runs fine, once I let off the primer button the unit stops burning. have tried to turn off gas supply and open very slowly this does not work. have tried different tanks, this does not work. note, did leave heater on job and customer tried to use without plugging in (no fan) this is when problem started. any ideas?
Posted by dreeves03 on
4 Related Answers
Anonymous
  • 12 Answers
SOURCE: the gas does not light
get a new unit dont play with propane it goes bang!!
Posted on Nov 01, 2009
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: I have an All-Pro 40k Btu SPC-40a heater that
If it effecting the pilot light only, yes. If it effecting the main burner, you will need a thermo-pile or pile-generator.
Posted on Jan 19, 2010
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: L.P. Propane Heater not staying lit
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 30, 2010
Anonymous
SOURCE: The heater that I purchased
not sure if solution went threw.If not check the fan motor.rotate blades motor may need oil or replaced.Good Luck
Posted on Feb 15, 2011
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
I have a reddy heater rlp30 propane forced heater 30,000 btu. Heater lights ok but will not stay running unless i hold red bypass in, when i let go the heater goes out. Do i need a thermocouple or...
achowe - Several things can cause what you have described.
Restricted air flow. Check the heater's inlet & for any obstructions.
Damage Fan - check the fan for any obvious damage.
Excessive dust or debris inside the heater or in the surrounding area.
To help you more, I am including a link to the Owners Manual for your heater. You can download and print it for future reference. If you find you need to order parts, they can be found online at Master Distributors. They stock all the parts for DESA/Reddy Heaters.
http://www.desatech.com/manuals/Construction%20Heaters/BLP42A.pdf
Hope this helps you solve your heater problem.
Apr 10, 2011 | Heating & Cooling
I have a spc-40 heater i can not get it to stay fired up i press the fuel button and it does lite but after 15 to 20 i release button and it goes out what do i need to do to make it work again
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
Feb 28, 2011 | All-Pro Propane Garage Shop Heaters - All...
Heater wont stay lit when i let go of primer button after a few seconds
try holding down the button for 15 to 20 seconds and then let go ( this will let the system heat up to the proper temp ),, if it still will not stay lit then the thermal coupling is bad and needs to be replaced.
c...
Jan 24, 2011 | All-Pro SPC-85 Utility Heater
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I have an All-Pro 40k Btu SPC-40a heater that won't stay lit,, is this a thermocoupler issue?
Jan 19, 2010 | All-Pro Heating & Cooling
No heat
It is either the igniter or the limit. Their is a limit mounted
at the 12 o'clock position beside the igniter. If you look at this video you will see it. Well the base of it and 2 philliphead screws that hold it anyway. LOL
Check ot the video HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2010 | All-Pro Propane Garage Shop Heaters - All...
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
Heater will not stay lit
Leave automatic button depressed for 30 seconds after flame ignites.
Jan 14, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
154 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
