Is the antifreeze leaking out of a small hole on the water pump housing just behind the pulley?
You need to know exactly where the leak is coming from. If the pump is not leaking then there is another location.
Generally pumps either work or leak. They do not slow down and overheat the engine.
Where did the smoke come from? Under the hood or out the exhaust pipe? If you blew a head gasket and the exhaust was blowing steam that would cause overheating. The original leak under the engine would cause overheating that then will cause other problems like blown head gaskets.
Did you use stop leak or some quick fix? what did you do to stop the original leak?
