Jado 827-850-144  Shogun Single Lever Kitchen Faucet with Pull Out Spray - B... Logo
Posted on Jan 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Jado Shogun faucet with side spray. When I turn on the hand spray, only about 25% of the water comes out through the spray. The remaining 75% of water continues to come out from the faucet. How can I fix so the water comes out from the spray with pressure and not out from the faucet?,
Tony Crow
Level 3:
Master:
  • Master 578 Answers
  • Posted on Jan 29, 2018
Tony Crow
Master
Level 3:
Master:
Answers
578
Questions
Helped
143247
Points
1638
Faulty cut off to faucet , calcium ,'
5 Related Answers
Anonymous
  • 171 Answers
  • Posted on Sep 10, 2008
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Anonymous
  • 334 Answers
  • Posted on Dec 06, 2008
SOURCE: side spray has very low pressure
Disassemble the sprayer and remove the dirt and dibri gathered inside.
Reassemble.
Has the water been turned off to that faucet, or the entire home recently? If yes, it probably loosened sediment in the pipes and its clogging the sprayer.
Anonymous
  • 50 Answers
  • Posted on Feb 09, 2009
SOURCE: victoria faucet Jado 51.C how to access
Here is a link to the repair parts page on Jado website for your faucet. Exploded diagram shows how the thing goes together...
http://www.jadousa.com/assets/repair/842001_repair.pdf
The handle assembly and collar (8) will thread off after pushed past the limit of the cartridge (gentle consistent pressure)...
In terms of leak itself its hard to say but if the faucet froze from sediment build up and is now leaking it is likely that part of the cartridge is 'clogged' open...
Hope that helps...
Bill Johnson
  • 306 Answers
  • Posted on Jul 29, 2009
SOURCE: The faucet continues to run when using the side spray.
under the neck of the faucet is a small cone in the side of the body.this is your spray diverter,it may be clogged,it may be spring loaded or a presure valve you must remove and clean. then it will work right.
I have a 20+ year old Jado bathroom faucet. My plumber could not get it apart and suggested I cut it out and get new one. Can you suggest a plumber with experience like this who knows Jado?
If he knew how to disassemble the faucet but it was corroded so badly it would not come apart<?>... sometimes a Dremel with cutting wheel is the only option.
If he wasn't familiar with "JADO"... ask JADO to help identify your faucet.
http://www.jadousa.com/default.aspx?aspxerrorpath=/searchResults.aspx
Get the technical documents yourself and then find a different plumber.
Defective Jado classic master bath products
sounds to me as though the problem might be coming from where the drain and pop-up rod meet,..you know how there is usually some little parts i.e.; o-ring, teflon bushings, etc. that HAVE TO BE put in in order,? check that stuff out and if it fixes problem, what looked like bad a spout might not be anymore,......
How can I adjust the hot water? Right now, at its
I looked at spec. sheet but found nothing for temp. adjustments so I would have to say try turning up water heater a little at a time.
How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
1helpful
Pull out spray don't go back
Hi, most pull out sprayers have the hose hanging under sink, the one you had to pull to retract. They come with a weight that is to be installed at bottom of loop with sprayer in "parked" position. If there is no weight, that's the problem, if there is, make sure there is nothing in the way of full movement of this hose when it pulls into the parked position. It can sometimes also be something like a wood splinter, clamp, screw, pipe or other obstruction rubbing against your hose keeping it from falling properly (as longg as that weight is on it). Let me know if this helps! Thanks
4helpful
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 • Plumbing
Top Jado Plumbing Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Jado Plumbing Expert? Answer questions, earn points and help others
