Panasonic sc-sp100 i pod docking station speakers not working. all lights coming on and when turned right up low buzing can be heard but appars to have no link when my ipod is placed on it.
You can change the Radio station by using the button on the top of the stereo system. The double arrows left and right will change the radio station when in "Radio" mode.
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Have you checked the contacts where the device slides into it? First thing I'd try is flipping the dock upside down and sweeping a small paint brush along those little metal contacts, to make sure there's no debris in them, keeping them from making contact. Make sure that the metal contacts are in proper alignment to fit with the contacts in your device. Also if the contacts aren't shiny metal, a piece of fine sandpaper run gently along them will pull the corrosion off.
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
I think some docking stations do not work with Iphone3 + as the hardware has been changed by Apple. Thye warned all manufacturers about this but many ignored it! There is not solution other than to buy a station that specifically says that it will play Iphone3 +.
You need to dismantle the unit and resolder the ipod socket. It is soldered to the board and the solder joints crack under the strain. This will happen to every JBL dock eventually.
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
