Question about Nokia 6303i Cell Phone
My nokia 6303 Hang while it start only nokia appear after tht dark screen appear no process further, cell cannot start.
Anonymous
    New Friend:
Problem with the Nokia 6303i Cell Phone
  • My nokia 6303 Hang while it start only nokia...
Posted on Apr 01, 2011
Anonymous
Nokia 6303 hang on nokia logo without baclight
Posted on Mar 07, 2011
u2ugsm
    New Friend:
  • 27 Answers
It can be due to software problem make it flash with latest firmware to for battery problem in Nokia 6303 Low Battery Hang
Posted on Feb 06, 2013
Shahid Saher
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
It Is hardware Problem i think your cell phone is old and lcd strip is not fully connected with pcb connector just open your handset cassing and clean lcd connnector with ctc or petrol .Note please carefully work when remove lcd strip .dont damadege it .if problem not solved then may have some lcd connector lines are broken .
Posted on Apr 19, 2014
Nokia 6303 restricted code
Hi, You can get the restriction code for a Nokia 6303 from www.unlocking4u.com at affordable cost with easy step by step unlocking guide.
Jul 11, 2012 | Nokia 6303 Cell Phone
Sir i have nokia 6303 classic mob which phone memory crrupted by virus so pl tell me process for formating phone memory
This is the best and 100% guarantee solution.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6303 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 18, 2011 | Nokia 6303 Cell Phone
Hi i m having nokia 6303c... i want to do factory reset but dont know the security code... i tried master code also but tht also not working...plz help
Hi, the standard master reset code for nokia is 12345. But if fails, you can get the code here for FREE*) :
www.nfader.su
Regards, Jay
*) need to key in your IMEI #
Aug 25, 2010 | Nokia 6303 Cell Phone
How repair lcd 6303
Buy a new lcd from here: http://www.ownta.com/original-nokia-6303-cell-phone-reparing-lcd-display-screen-replacement.html
Add 1 pcs of opening tool, you can easily fix by yourself.
Good Luck !
Apr 18, 2010 | Nokia 6303 Cell Phone
While transferring multimedia in 6303 the phone dims off and black screen appears
that means your phone is condemm... maybe you get cheat from seller
Feb 28, 2010 | Nokia 6303 Cell Phone
Nokia 6303 wont work
You have to update your phone's firmware or re-install your phones software from an authorized Nokia Care Center.
Jan 01, 2010 | Nokia 6303 Cell Phone
When i switch on my nokia n72 ,the white screen appears with nokia logo and it doesnt start further..its being hang for last..i was vexed with it up..plz kindly help me how to fix it. n 72 white screen...
i think that there is a problem with your phones's firmware!! it hangs repeatedly !!!you must upgrade it!! go to nokia care and they will do it for you for rs 200!!!
Oct 13, 2009 | Nokia N72 Cellular Phone
Nokia N72 hangs up
if yon know how to repair mobile so change boot ic othervice contact your nearet mobile repirer..
Jun 02, 2009 | Nokia N72 Cellular Phone
Hangin out last
Virus problem try formatting your cell.
If this doesn't work tell me.
Sep 21, 2008 | Nokia N72 Cellular Phone
Nokia 6303i Cell Phone Logo
1,171 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
matt
matt
