I've got it!!!!!!!
Although this is an old thread, recently I had
an idea about my own Toshiba DVD Recorder. Same problem all over the
grid when it comes to this model and hopefully some of you who currently
have this problem will find my post and once again be using your unit
as I am mine. The problem is so simple you'll flip! This Toshiba DVD
Recorder device is exactly what we're all using as DVD burners in our
home pcs, just a Toshiba in this one though, I had an LG multi-writer,
dula layer, blah blah blah and when I opened up my Toshiba unit, saw how
the screws go into the sides, the IDE connector is EXACTLY what we will
find in our PC's, the Toshiba jumper pin was set to MASTER and like
modern day DVD or CD drives, we no longer need to connect an audio
connector to get what else, but audio.
Early today I looked
closely at my LG replacement unit, saw that the tray is more shallow
than the original Toshiba one. Most of you know why the tray is so deep?
Because with this unit one can use the cartridge-style DVD-RAM disc but
since a PC's dvd tray is not as deep, I just ripped into the case and
used the actual ram disc without it. The Software Version for the
Toshiba is ZN10 and the DVD Drive Software WAS 1309. The drive software
will change to whatever your newest PC-DVD recorder will be. In my case I
had a 2006 LG and the Toshiba was a 2004 but irrelevant anyway. One
thing you must remove from a PC type DVD recorder/burner, is the front
access door and the surrounding trim since inside the Toshiba home unit,
no door or trim attached to the Toshiba's DVD unit but of course you
would notice that the silver door opens when the eject mech. is
actuated.
For 2 years my Toshiba was malfunctioning, would read
older discs I had recorded and finalized, some of the other discs I had
recorded some things on but didn't finalize, I was able to do so today.
The problem I have heard about these Toshibas is that their laser units
are el cheapo but kind of ticked me off because we paid $550 in 2004 for
this thing and no hard drive of course. I do have an issue with my
clock on this thing and maybe because we had it plugged in for the past 8
years or so. When off, nothing on the display, when turned on the
display shows the time and then it blanks out and we can only see the
elapsed time, counter etc. Not that it matters but don't think I'd ever
buy another Toshiba device anyway now.
Hope this has helped and
trust me here, if your unit still powers on and you keep seeing the disc
read error etc., you can probably find yourself a brand new dvd
recorder for about 30 bucks retail and problem solved. Oh yeah, one
interesting note and if I hadn't mentioned this now, some of you would
realize it anyway, this unit will now record + and - since it's actually
a PC recorder device LOL. Stupid Toshiba made this as only one type and
that was -R but for the life of me, can't figure out why it couldn't
have been both/all types. Really have to add about what I was reading
awhile back too, some were advising that one couldn't use -RW types
(rewriteables) but the issue actually stems from the laser and unit's
weakness at reading better quality discs. The ones I had copied and
finalized as WRITE ONCE (only) were really cheap ones and they have
always worked. Prior to doing this unit swap I tried a store bought
movie and it wouldn't read it at all, then when I did the hardware
change, VOILA!
I hope you get the alert to this solution below and then get yours working too! I don't mention this below but I was even thinking of taking mine in to a shop to see what they would charge to fix it-probably 2 or 3 hours and parts etc. or maybe a few hundred bucks. Forget it, mine's running now and it was actually as simple as you will read below. If you do tackle this yourself, make sure you GROUND OUT your hands by touching a few metal pieces on the unit so you don't end up sparking something like circuits etc. Good luck
