Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My sandisk crzuer is not responding. what can be done to reboot it? or how to recover data? The only message i am getting is " do you want to format now? please help.
Posted by samisiddiqui on
Anonymous
    Scholar:
  • 24 Answers
It sounds like your media is malfunctioning (controller issue).
Our company, LC Technology, is the only Sandisk-approved
data recovery company and we have been working on their products
for over 5 years. You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Sandisk with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Jan 12, 2011
Anonymous
    Sergeant:
    Champion:
  • 283 Answers
Your scan disk seems to be corrupted try to run an antivirus on the drive with a little luck you files might be saved
Posted on Jan 08, 2011
How do i recover my deleted photos from my sd card?
There are numerous software utilities that do that. SandDisk has their own as well. Go to:
http://www.easeus.com/data-recovery/data-recovery-software/free-sandisk-recovery-software.htm
Oct 06, 2014 | SanDisk Ultra SDHC 32GB High Performance...
Tip
Recover Deleted Photos From iPhone 6
It can be most aggravating when an important photograph is accidentally deleted. If you have an iPhone 6, then thankfully, there are a few options available for flv files recovery from this device. Remember, it is good practice to back-up your photographs every now and again by saving them onto an external storage device.
One of the first things to do in trying to retrieve deleted photos from an iPhone 6, is to open the Photos app on your smartphone. Once you have done that, do the following steps:
1.Select the "Albums" menu.
2.Select the album that you need and then select "Recently Deleted."
3.A list of all the recently deleted photos will appear.
4.Select the ones that you want and then tap on the "Recover" button to recover all the photographs that you selected.
5.All restored photographs will be sent to the album in which they were originally located.
If the photographs that were deleted were backed up in iTunes or iCloud, they can also be recovered. The important thing to remember is to have either iCloud or iTunes backup turned on at all times. If you are unsure how to do so, here's how:
1.Go to the "Settings" menu then select "iCloud."
2.Under "iCloud", select "Storage and Backup."
3.Then turn on the "iCloud Backup" feature on your iPhone 6.
4.As long as your iCloud backup is up-to-date, then all your photos can be easily restored to your iPhone 6 in case of accidental deletion.
Backing up your photographs to iTunes is equally as easy as backing them up to iCloud. However, once you connect your iPhone 6 to your computer or iPad, you need to ensure that iCloud is turned off; you can back-up to one or the other but not both apps at the same time.
If your photos have been deleted, then recovering your duplicate photos from iTunes backup or iCloud backup is not a problem. Simply launch iCloud or iTunes, right click on iPhone (the device in question), select "Summary", and then select either "Restore from iCloud Backup or "Restore from iTunes Backup." Once that is done, wait for "Restore in Progress" to complete and your device restarted.
When all else fails, a reliable data recovery software can be used to recover deleted photos from an iPhone 6. uFlysoft is one such user-friendly software that gets the job done quickly and thoroughly. The process is simple and takes these easy steps:
1.First, connect your iPhone 6 to your Mac computer then launch the uFlysoft data recovery software. You never want to launch a data recovery software directly from the smartphone from which you are trying to recover lost or deleted data.
2.Select the "Recover from iOS Device" option.
3.The software will then scan your device and present all the recovered photographs for you to preview.
4.The recovered photos can then be saved to any storage device or the computer itself.
RE: http://www.uflysoft.com/
on Feb 11, 2016 | Apple Genuine Original Iphone6 Earphones...
Tip
How to Recover Files and Photos from SanDisk USB Drive?
<span><span><img src="maggiena_6.jpg" /><br />SanDisk USB flash drive is widely used for its excellent quality. It gives customers all the power and performance you need to transfer, store and share pictures, tunes and data with easy. Some uses of SanDisk USB flash drive can be concluded in the following aspects: personal data transport, secure storage of data, application and software files, application carriers, computer forensics and law enforcement, backup, etc. Compared with other storage devices like floppy disk, USB carries various advantages for Small size, lightweight, rewriteable and removable. Therefore, it becomes a necessary among business man and students.<br /><br /></span></span><span><span> <p>However, Data loss often happens on USB flash drive as well. Some of them are caused by the products of USB, others due to the false operation of it. Here are some typical reasons that cause data loss:<br /> <p><img src="li.gif" />1. Windows system asks you to format USB drive and you accidently press "Format";<br /><img src="li.gif" />2. Mistakenly or carelessly delete files from USB flash drive and cannot find them in the recycle bin or trash bin;<br /><img src="li.gif" />3. The drive was attacked by virus and files get hidden or deleted;<br /><img src="li.gif" />4. Not properly remove the USB drive from computer when the data was still transferring;<br /><img src="li.gif" />5. The file system of USB drive was displayed as raw;<br /><img src="li.gif" />7. Hardware malfunction<br /> <p>It is really frustrated if you find crucial documents, previous pictures or applications lost. Are there any methods to get them back?</b><br />Data loss caused by hardware malfunction will be very hard to restore. You have to ask the help of professional technician. For other cases, you can rely on some<span> </span><a href="http://www.card-data-recovery.com">USB flash drive data recovery</b></a><span> </span>program to help you. Once loss data, you should stop using USB any more in case the data was overwritten. There we recommend you Card Data Recovery to help you<span> </span><a href="http://www.card-data-recovery.com/">rescue USB flash drive data</a>. <br />Step1.</b><span> </span>Download Card Data Recovery, save it to your computer's desktop and double click on it to open the program;<br />Step2.</b><span> </span>Insert SanDisk USB flash drive into USB port of your PC;<br />Step3.</b><span> </span>Run Card Data Recovery and select SanDisk device from the drive selection drop-down menu. Click "scan" to scan the USB drive and you can find deleted or lost items will be displayed in the task list;<br />Step4.</b><span> </span>Select the files you wish to recover from USB drive and click "Recovery" button. Card Data Recovery allows you to preview files before recovery.<br /> <p>Card Data Recovery also supports recovering data from<span> </span>SanDisk memory card</b>,<span> </span>SD card</b>,<span> </span>mobile SDHC card</b>, etc.<br /></span></span><br />
on Jun 08, 2011 | Computers & Internet
No data found
There is a program called get data back that will recover data from flash memory devices.
Jul 03, 2013 | SanDisk Computers & Internet
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Facebook retrieval of a message
There is a way of recovering deleted facebook messages.
In order to recover a facebook conversation:
You must receive email notifications from facebook, telling you when someone sent you a message. Ex. Paul Wilson sent you a message on facebook
Click on that link.. If you have already deleted the notification, go to your deleted messages inbox (hotmail)..
(It's impossible to completely remove something from a computer!)
At the bottom of the message, you will see a link, click on the link that says :
To reply to this message, follow the link below :
ex. http://www.facebook.com/inbox.php?lh=0e5633de8d92e7fab7145ffc710260dc&
then click on : SHOW DELETED THREAD.
Done!
Jun 07, 2010 | Facebook Social Network
My cruzer micro 4gb flash needs compression but I get the message drive not formatted. How can I recover the data without formatting the flash drive since formatting will erase all of my data?
You can run a data recovery app on the drive and attempt to pull off any data still accessible. I recommend the GetDataBack Data Recovery apps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
''Permanently Inaccessible'' Flash Drive
Of course you can recover all your data whether its being reformat at first. But if you format that in second time i don't thinks its possible. Using a program that is very helpful to us is the idea of recovering all kinds of data such as documents, pictures, sound files & etc. Possible 80% Recover of your Data.
Here is what you do to, #1 Download a software freeware by using a UTORRENT at www.download.com/utorrent or this link too www.utorrent.com. #2Go to the website www.torrent-finder.com at search engine type RECOVERMYFILES then ENTER. #3 select a program RECOVERMYFILES with serial/crack appear listing in the window then download it using a UTORRENT program. #4Follow the instruction if you downloaded the files.
Leave a comments if you have don't understand of my instruction. Hope this might help you. I'm sure you get your DATA on it. Good luck!
Aug 06, 2009 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
80 people viewed this question
Top SanDisk Computers & Internet Experts
k24674
Marvin
Marvin
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
