There is no other solution then to that problem with a CLP500 to bought a new/secondhand CLP510N and replaced the unit. Problem will be solved accordingly. if you dont know how to replace, contact nearest Samsung Service Center.Good luck do rate the solution if got help
ther is a prob in your fusing unit, chances are the thermistor is not working, if you can still feel some heat in this area, either the lamps are working fine but the sensing device fails to read the actual temp.
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
