1-tilia foodsaver,prof II,part# 35-0320 grey and the other tilia food saver prof II ,part # 35-0303 white. these both have worked until yesterday and now both will not work. I only plugged and un plugged both units several times with no change.
Try this procedure:--
It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base 2.Plug the food processor in and turn it on 3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed 4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl 5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more 6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model) 7.Slide the lock to the right into the locked position The food processor should now work.This will help.Good luck.
The transformer can be found at a good wholesale electronics store, it is 12 volt and will register slightly higher with ohm meter. You can also use a 220 to 24 volt transformer.
It usually goes something like this, with minor variations depending on model number: 1.Remove the work bowl completely from the base 2.Plug the food processor in and turn it on 3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed 4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl 5.Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more 6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model) 7.Slide the lock to the right into the locked position
-Tha Mp3 Doctor
-Tha Mp3 Doctor
