Question about Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch
I recently purchased a badger lecoultre master compressor memovox with an alarm pre otroubled am having trouble setting the alarm. I would appreciate any help you could give me.
Posted by xddaniel01 on
I can't set the date on my watch - right now I have to scroll through the time setting mechanism hour by hour and day by day?
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
Jun 09, 2011 | Jaeger-lecoultre Master Compressor Memovox...
Good Day Guru! I have a LeCoultre Automatic and it keeps excellent time. My problem is that the face has deteriorated,flaking off. Is this watch worth repairing and where would one have this...
To restore the watch back to it's original condition it will be very expensive, this kind of work is usually done at the factory because it will need extensive parts replacement. My advice would be abandon the idea because of cost, but! if you feel going that route take it back to the store where you purchased it from to see if the work can be done. Some manufactures stop providing parts after a few years making it impossible to remedy the situation.
Mar 19, 2011 | Watches
I have jlc movement 450 with dial but case is missing
cousinsuk.com choose branded watch parts, select the brand and search. They are in England but I use them all the time, you have to go through there little signup procedure but whatever it takes, right?
Feb 12, 2011 | Jaeger-lecoultre JaegerLeCoultre Master...
The moving mechanism inside gets stuck and i have to violently sheck the watch to get it lose and start working
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jun 25, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Problems with setting the date on this watch
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jun 21, 2010 | Jaeger-lecoultre Master Compressor Memovox...
How do i get the temerature guage to work on the secto mountain master? I recently purchased a Sector Mountain master 4 days ago. I have been reading the instruction manual over and over and I have yet to...
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals and these may differ from yours.Rate me, please.
Mar 25, 2010 | Sector 3251908015 Mountain Master watch
Vintage 1940. Doesn't run. Numbers on back of case illegible. Dirty, but intact. What have I got?
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
Jan 24, 2010 | Jaeger-lecoultre Watches
Winder has broken off jaeger-lecoultre watch
Yes, but for an authentic Jaeger-lecoultre watch it will be very expensive.
Dec 30, 2008 | Jaeger-lecoultre Reverso Classique 2798120...
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
My memovox is running too fast got it now for about a month
Your question was cut off please explain your problem further Don
Jul 01, 2007 | Jaeger-lecoultre Master Compressor Memovox...
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
Top Jaeger-lecoultre Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
