Question about Sony DDS SDT-9000 DAT Tape Drive
I have a IBM xSeries 8668021X with a embedded Dual channel Adaptec 7899 controller on the mother board. I have down loaded the SONY tape tools and ran diagnostics against the drive. The drive works. However when I open the accessories\system tools\backup application the system cannot find the tape drive. When I look in the hardware manager it shows the tape drive as functional but has no driver associated with it. When I load the Sony driver (from the sony web page) and reboot the system, the drive now has an driver error (yellow question mark) on the tape drive inthe hardware manager. This tape drive worked under Windows 2000 PRO but doesn't work now under my XP Upgrade. Any body got an Idea
Posted by jim5251 on
Anonymous
    New Friend:
  • 19 Answers
Did you load this driver? sxpdds_32_2600_102202_v1.0.0.2.zip http://sony.storagesupport.com/node/471
If so check the Windows Event Viewer System log for possible errors from the driver.
Posted on Jan 18, 2011
I get 3-3-3 beeps no display
Check ram , remove ram and clean it and ram slot also , then fix ram on ram slot then start , if does not start then use another ram , then after all its does not start then check you mother board
if it is helpful then vote yes
Mar 25, 2015 | IBM eServer xSeries x226
Ibm xseries 226 is not initializing.. the fans start when i power onn the system but not more than 5-10 seconds.. and there is no display.. there is only one processor on board right now. pls help
If you are comfortable getting inside the PC here's some things you can try.
  1. Take the side panel off and pull the memory sticks out. Now turn the PC on without the sticks in it and listen for a screaming banshie. If you hear the screaming banshie it means *********** board should be okay. If you hear no noise at all there you may have a bad mother board. 6df7c5d.jpg
  2. While inside the PC unplug all cables for about 10 seconds and plug them back in. Do this one at a time so you don't loose track of where they go. Also carefully pull the processor out and plug them back in. Turn PC back on and test. 3513f7b.jpg
  3. Unplug the power supply from the mother board and plug it onto power socket by itself without having anything connected to it and see if it runs okay on it's own. If not it's probably bad.
  4. Last but not least If you know how to boot the PC into the BIOS configuration do so and check what temperature the PC is set to shut down at.
Hope this was helpful.
Good Luck
cookEmonster
Oct 15, 2010 | IBM xSeries 226 Server
My windows vista has no audio device indtalled how can I fix it?
Hi the problem you are having is with the drivers for the mother board what you need to do is find out what the main board is in your computer their should be a printed part on the mother board that tells you what mother board you have then using google type in drivers for (enter make and model of mother board here then press enter)
then download the latest drivers for *********** board and install them this will get the sound working again
Aug 14, 2010 | Microsoft Windows Vista Ultimate Edition
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Ibm server xseries 326
It is not detecting the HDD because the windows install does not have the necessary drivers. On the windwos install you must press F6 or F2 I don't remember which one but it prompts you for them to load external drivers fro SCSI or other type of drives, you must download the right drivers for the type of HDD the server has probably fromt eh IBM support website, put them in a floppy and load them from the floppy into the windows install so it recognizes the drives..
Jun 02, 2009 | IBM eserver xSeries 360 8686
CMOS erroe 0193
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
Oct 12, 2008 | IBM NetVista PC Desktop
Cant create additional raid
if there is a limit this would have been mentioned in the features of the product
please have a check
Aug 01, 2008 | IBM xSeries 226 Server
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Sony DDS SDT-9000 DAT Tape Drive Logo
413 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
