Acer Aspire X3910-U3012 (PTSED02010) PC Desktop Logo
Question about Acer Aspire X3910-U3012 (PTSED02010) PC Desktop
How do I get my Aspire AX3910 to recognize my surround sound stereo via HDMI? My computer is only showing 2 channels. I need it to give me a surround sound option, yet it's only giving me stereo as my only option for audio output. Please advise what I can do to get surround sound going to my stereo from my computer. I'm using the HDMI from the computer to the stereo to my tv, with my tv being the monitor.
Posted by carter0 on
Catalin Turcu
  • Acer Master
  • 4,924 Answers
It would help if you use windows 7 ..cause it has the possibility to select the digital out on the sound settings .If you use xp ..you have to open the sound manager and click advanced ..and if it only have the stereo choice t measn the system is not capable to send info in other way ..via hdmi ..and choose stereo ..and select the surround on the tv ..if it is next in line for processing the signal .
Posted on Dec 20, 2011
Yamaha RX-v685 - Surround Sound Issues
If you are in Pro Logic mode and play a stereo recording/film etc, there will be no rear sound.
You need a Pro Logic recording to produce true rear sound.
Surround speaker is not working.
Make sure your receiver is in surround sound mode on the sound fields for that input. Some receivers have independent sound mode settings. example would be hdmi 1 is set to 2 channel stereo while hdmi 2 is set to PL II movie which is a surround sound setting. Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Element tv code direct tv
Not following... This is what I think you may be saying: You can't get the TV to use the RCA input?
The reason for my confusion is "rca surround sound". RCA will only carry left and right channel (stereo). It can't push surround sound unless it's setup as a direct input [typically an 8 channel input, where you would have 8 RCA cables (or 4 pair) connected].
The headphone jack, if using a 4-pin headphone jack (it has 4 sections of metal, vs a 3-pin, which only has 3 sections of metal), may be able to send something closer to surround sound, but it wouldn't be a true surround sound. You would need to use fiber optic, HDMI, DVI, or digital coax cable.
The sound settings in the OS on the computer need to be set to push the surround sound, or it will only push stereo. You'll probably need to spend some time there testing all the setting options.
1helpful
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Hi, I have a Panasonic Blu-Ray Suround System with a Satellite HD box plugged into via optical. On normall channels the surround sound works fine, but when I switch to a HD Channel I get no sound. Any...
Check your sound settings on the satellite box, they might be set to output only to hdmi on hd, or the stereo/surround settings are messed up. If not giving a call to your sat tv provider might help because if it is a common problem they will know about it, and don't forget to do a full restart of the devices, this has worked wonders for me.
Hello i have a medion 5.1 active sound system and i am trying to install it to an acer 5335 laptop but for some reason it will not work. i am using the usb method can you give me some advise and help...
hello Paul,
I understand that you wish to connect an laptop computer that has a standard stereo out(2 channels), earphoe jack or adio out to an active stereo system that supports the dolby 5.1 multichannel souround sound.
That is where the problem starts.The active sound system has more input channels than the two stereo channels given by the laptop, so connecting them via adaptor (audio out from laptop, earphone-like, 3.5 mm' male' jack to red and black chinch plug,'male' version to stereo L(left) and R(right) channel in at the active system) may provide you with extra stereo sound enhancement(like any other amplifier would), but no real surround sound..
To solve this, you would need a stationary desktop PC with an extra surround soundcard
that has all the multi channel out in it, as there is no chance to upgrade your laptop with such devices I am sorry to tell you that you perform an impossible task to get surround sound from your laptop.
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
No sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Steve Sweetleaf
Steve Sweetleaf
shadow
