Question about Samsung Smooth SCH-u350 Cell Phone
I have a Samsung Smooth and it wont turn on past the first loading screen. I took out the battery, waited, and put it back in, several times, and it still wont turn on. What should I do?
  • 321 Answers
What you need to do is to first check if the battery is properly charged. Insert it in another phone and try to power it on, if it turns the phone on and stays on for a while, then it means the battery is alright, but if it does not power it on, then it means the battery is weak and cannot power the phone on beyond the loading screen.
Also you need to test the phone by trying to use another well charged battery in the phone to see if will turn on, if it does turn on, then you know it is the battery that is faulty, but if it does not turn on, then you know the problem is from the phone.
First get the phone flashed before you can commence further repairs on the phone.
Hope this information helped.
Posted on Jan 07, 2011
Less than a week old phone will not turn on.
have you bothered to recharge the battery as with a lot of use it will be flat within the week
Feb 09, 2016 | Microsoft Visual Stdio Fun Svr Sa Nl
Samsung prepaid phone
Was there any physical damage from a fall or water? What is the model and what is the age?
Apr 24, 2013 | Cell Phones
My galasy s 4g model d700 wont go past the first screen it stop working what can i do?
while the phone is on, remove your battery, after 5 to 10 seconds put it back.. then switch it on.
Dec 16, 2012 | Samsung Sprint Galaxy S Epic 4g Sph-d700...
My samsung smooth got wet i let it dry but will not turn on
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 08, 2012 | Samsung Cell Phones
My samsung genio touch wont turn on past the loading screen it just freezes how can i fix this?
my samsung genio touch wont turn on past the loading screen it just freezes how can i fix this please i really need ur help
Jul 17, 2010 | Samsung SGH-J600 Cellular Phone
My Toshiba Terca A8 wont Start
I assume that by now the battery has discharged past the point of being a useless diagnostic tool. Either the charger failed or the laptop failed. Have a reputable repair person put in a freshly charged battery to see it the machine will run off battery only. If not leave the whole unit with him/her for repair.
Mar 27, 2009 | Toshiba Tecra A8-S8514 Notebook
Samsung A707 Stuck at startup screen (loop)
No hard reset wont help!You should try following to get rid of this problem:
  • Change your phone's battery.
  • Change your charger.
  • Hard reset wont be possible in this case.
  • You should also consider charging your phone for long time but still if does the same loopy thing then change your charger.
Thank you and good luck!
Mar 06, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
My phone keeps freezing...
my phone froze and i attenpted to turn it off several times, after trying and not getting a response i took out the battery pack and placed it back in and turned the phone back on. after turning the phone back on it kept freezing a
Nov 24, 2007 | Nokia N81 Smartphone
Samsung Smooth SCH-u350 Cell Phone Logo
304 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
