Question about AT&T Quickfire Cell Phone
My screen scrambles and i can't get it right - AT&T Quickfire Cell Phone
Posted by gatorqb16 on
Anonymous
  • 321 Answers
The problem with the phone that is causing the screens scrambling is that the flexi ribbon that supports the slides of the phone is getting weak or worn out, therefore, fixing the flexi ribbon of the phone will correct the problem for you. You will have to disassemble the phone to be able to replace the phones flexi ribbon. If you are not familiar with such repairs, i will advice you seek assistance from a friend who is technically able to assist you with disassembling and reassembling the phone back together.
Hope this information helped.
Posted on Jan 07, 2011
Scrambled laptop screen
Scrambled is a subjective term that is useless in trouble shooting.
Sounds like a virus.
I have problem with my EcoQuest air purifier. The display is unreadabl Its all scrambled it
I am having the same problem right now. Need to replace the LCD screen. Still checking things out.
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
I dropped my laptop on the floor, it fell on a corner, the screen is scrambled on the right side for 1 inch and the top right corner is black like a broken window what shouls I do? Thank you
You can either replace the screen or you can work on your laptop with a broken screen. Replacing the laptop screen is quite costly depending on your laptop model and availability of your parts.
1helpful
2answers
My screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
1helpful
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
1helpful
The screen is scrambled at times. It seemed like
it's probably not the LCD, it is most likely the ribbon cable... it could be repaired or if not, replaced...
4helpful
Scrambled image
This can be fixed as it is ccd imager problem and that part will be replaced.
Canon will repair A70 digital camera Free of Cost for ccd imager problem.
Click Canon CCD Imager Advisory for details.
Bottom screen scrambled on nintendo ds lite
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device following this info:
How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
The bottom screens have 2 wrap wires, one big and visible, that is the screen cable, the other is small and not so obvious and this one is for the touch screen and you dont want to get it broken.
The cable connectors release the cable by lifting ot pulling the brown or black lock and be sure to remember how it was connected so you can know the right position of the cable when connected right not having any problem with loosen cables before you finish.
Good Luck...
AT&T Quickfire Cell Phone Logo
Top AT&T Cell Phones Experts
Ekse
Muzahura Frank
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
