Cambridge Soundworks BassCube 12 Speaker Logo
Question about Cambridge Soundworks BassCube 12 Speaker
Why does basscube speaker click when system is turned off. There are clicks about every 5 to 10 minutes.
Posted by cobusek on
3 Related Answers
Anonymous
SOURCE: Panasonic SC-PT467 Wireless speakers Clicking
I had this exact problem. The clicking is something to do with interference from the power supply cable. It seems that facing the wireless unit in the most obvious way ensures that the power cable and the right speaker cables cross. All I did was turn the unit around so that the wires no longer crossed and magically the clicking sound disappeared forever!!!
Good luck !!
Posted on Feb 04, 2009
Anonymous
SOURCE: Yamaha YSP 1100 clicks when press power button but does not turn.
Hi
I have the YSP1000 and I had a similar issue but it was less frequent. I located the clicking sound which turned out to be a relay on the main circuit board. Before replacing it I removed the relay cover and cleaned the contacts. It has not miss behaved since and that was some 8 months ago. Give it a wizz
Mike
Posted on Dec 29, 2009
mlapres
Mike LaPres
  • 757 Answers
SOURCE: no speaker output from Basscube 8s
Yes. Check your connections that you are using from your preamp/processor or receiver to the Basscube to confirm that any adjustments I'll give you instructions for will go to the correct output. There are 2 ways that signal can be connected to the Basscube, your inquiry does not describe which you are using; either speaker level or line level. Line level is the easiest as it uses only one cable so I'll assume that is what you've used.
The following instructions I'll provide you with will presume that you are using a digitally controlled receiver or preamp/processor with an LED or LCD display and remote.
On the preamp/processor or receiver, navigate to your speaker setup menu and adjust the frequency output of any bass management system it may have to a full range signal. This may be a setting labeled for speaker size for example, choose "large." Or, if it has just a crossover setting, increase that to it's highest value.
Then go to the rear panel of your of your Basscube. Adjust the crossover to about 120Hz.
Return to your preamp/processor or receiver. Navigate to your speaker level control on the speaker setup menu. Increase this level to a matching value for each channel until you can hear your Newton speakers.
Posted on May 17, 2012
No speaker output from Basscube 8s
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
2answers
Has humming sound when powers on
You may have a power problem. Check to make sure that your wires aren't touching and not crossed.If this doesn't help try plugging in you sub to different plug could be getting interference electrically in the spot it's in
Why does the red light click to green without the speakers on?
That system responds to signal input, ie an electrical signal present on the input, in order to turn on the internal amplifier. If it is turning green without any input from the source, it could require service. It may be responding to static electricity...
The speaker should go to sleep after ten minutes or so, turning from green to red again.
1helpful
Loud humming noise
this may be result of blown capacitor - have it analyzed by applying strong magnet over the inside speaker , if humming persists, then its not blown capacitor -- the capacitor stores energy, and if that energy is lossed an out in the airwaves, thats the humming effect
2answers
Fuse blows wean speaker is on and burning plastic smell from amp side speakers work fine
the amplifier is drowing too much current, and components are getting heat from that
check your amplifier final stage tempreature,
all so check a short of the circuit.
Lost speaker laptop
Hi
the first thing that you can do is:if you remember when it was working , please go to:
sart , a;; programs , click on accessories click on it find system tools and click from next window find,
system restoration and click
when it opens chose at least one day befor that you know every thing was working , then klick restor or ok
after a few minutes your pc will reboot when it comes back on click ok with popup screen ,
it must be working now, if not please let us know for more assistance
thanks
2answers
BassCube 12 Startup Problem
same here. happened after moving residences
3answers
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Top Cambridge Soundworks Audio Players & Recorders Experts
Marvin
Marvin
David Shaub
shadow
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
