Question about Sterling Plumbing
I have a Sterling tub & shower faucet that is about 25 years old that is leaking. I have replaced the seats & stems but it still continues to leak a small steady stream out of the tub spout. The replacement parts were purchsed @ ACE hardware but they are not made by Sterling. Can this be fixed without having to replace the faucet?
Posted by marshallnann on
Alcolu John
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Your fixture body may be corroded beyond repair. Since you've replaced all the rebuildable parts, I'd suggest you get a plumber to check it but expect that you'll need to replace the faucet. Get a modern "cartridge" (Delta, Moen or Kohler) fixture that can be easily repaired indefinitely.
Posted on Oct 28, 2017
5 Related Answers
Anonymous
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
Anonymous
  • 14 Answers
SOURCE: Leaking tub spout single handle volumne/thermostat
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Posted on Dec 28, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
Anonymous
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have an American Standard Colony? bathtub faucet set that has been leaking at the spout. I thought the reason for the leak was the seats and rubber washers needed to be replaced. After doing so I still...
Check these items:
1. If you installed new faucet seats, did you add a little pipe joint compound to the threads before installing them?
2. Make sure the shower diverter is in the off position and you're not seeing water leaking from the spout that could be coming from the shower pipe or residual water from the shower head.
3. Make sure you have the correct faucet washers - some or tapered and some are flat and must fit the stem counter bore correctly and that the counter bore isn't damaged or the stem shaft isn't bent. Make sure the waskers are the correct hardness.
4. Make sure the screws that secure the faucet washers are tight, but not too tight. It doesn't hurt to add a little pipe joint compound to the screws.
Aug 28, 2010 | American Standard Colony 3275.505 099...
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
Problem with Sterling stem.when transfered to shower,still leaks
You did not tighten the stem enough, allowing the seat to rise just above the cavity where it will sit. You may also have scaling in this area preventing the seat from sitting flush.
Feb 03, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Feb 08, 2009 | American Standard Plumbing
Plumbing Logo
87 people viewed this question
Top Sterling Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Sterling Plumbing Expert? Answer questions, earn points and help others
