Coby CRA108 Clock Radio Logo
Question about Coby CRA108 Clock Radio
CRA108: I can not set the time. I hold in the time button down while pushing the hour and/or minute button but nothing happens. The clock actual is displaying a time that is not proper. It currently is displaying something like the following: 1P:G8. I unplugged the clock but when it is plugged back in it keeps on displaying 1P:G8 and will not allow me to change. The same goes for setting alarm time. Any suggestions?
Posted by bob9840 on
Anonymous
    New Friend:
My Coby CRA108 starting doing this after 6 months of use. Although I described the display as 1P:C8 since there is no key to properly display the character (hybrid of a G & C). I've left it unplugged and changed the backup battery with hopes it would reset. No luck so far. Anyone have success???
Posted on Feb 23, 2011
Anonymous
    New Friend:
Argh! This same problem just happened to our second clock. When the first froze on "IPG8," we returned it for a new one, figuring it was a fluke. The second clock has lasted about 5 weeks and now it is frozen as well. I'm gonna call Coby on Monday.
Posted on Feb 11, 2012
No auto set. I am not familar with the way to set clock
Some clocks are set up by holding clock button down and push minute or hour button. Hold alarm button set alarm. Some day hold button until flashing then set time.
How do i change the time
Hold down the S button until the hour flashes then push the arrow button until you get the correct hour then press the S button again (hold down) until the minutes flash the push the arrow button until the minutes are set.
4helpful
Set clock
Turn on the keys to 'Acc'. If your Legacy has a CD player, press down and hold on the 'disp' button for one seconds; if not, omit this step.
Push down and hold the 'disp' and 'H' buttons; this helps you to adjust the hour entry. The hours will be incremented by one hour; leave the button when the desired hour entry is set.
Push down and hold the 'disp' and 'M' buttons to adjust the minute entry. Hold down till the desired minutes entry is set and release it.
Turn off the keys to save the set time.
11helpful
4answers
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
19helpful
6answers
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
115helpful
7answers
Pioneer Supertuner IIID
To change the clock on this Pioneer stereo try this.
1. Press and HOLD the source button till the radio shuts off. Release the button.
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing.
3. Press the UP and DOWN buttons to adjust the hours.
4. Press the LEFT or RIGHT arrows to MOVE TO THE MINUTES.
5. Press the UP and DOWN buttons to move the minutes.
6. When complete, press the source button to exit.
15helpful
4answers
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
Trying to set clock
To set the clock, do the following:
1. Press and hold the MULTI-CONTROL button for 2 seconds
2. Rotate MULTI-CONTROL button until display reads CLOCK.
3. Push MULTI-CONTROL button up or down to adjust hour and minutes.
4. Press ESCAPE or SOURCE button to exit
2helpful
2answers
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
183helpful
15answers
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Top Coby Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
