There is NO manual On/Off switch on the TDK HD-01, instead it relies on the cassette deck's play head being engaged. This operates a microswitch inside the HD-01's housing. Ensure that your amplifier is switched OFF and there are no headphones attached to your deck as the magnetic pulse noise from the HD-01 can damage any sensitive connected equipment, including loud speakers. If it is not possible to switch off the amplifier, then ensure that the volume control is set to zero.
The little red LED should light in the HD-01 whilst the cassette deck's play head is engaged. If it does not light, either the battery requires replacement in the HD-01 or it is faulty. The play head only needs to be engaged for a few seconds.
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
