washing machine and the conditioner section in the dispenser is not emptying during cycle
This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: CONDITIONER NOT EMPTYING INTO MACHINE
have you tried cleaning the spray holes above the soap tray? if they get blocked up the water jets sideways and not into the conditioner tray. if it is blocked badly the header unit may need replacing. i dont think you have a water valve problem as you say some water is getting through.
SOURCE: Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
SOURCE: the conditioner drwaer fills with water after each cycle and the machine leaaks during each cycle
Check for pluged drain to washer ,check fill hoses for tighten fittings and good washer inside. (seal). The conditioner container may have a valve that has gone bad or pluged up. To much conditioner can plug this part up, Should check with a appliance repairman. If this is electrical, he should do the job for safety. Hope this might be of some help.
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
SOURCE: fabric conditioner compartment will not empty when in cycle
if you remove the drawer ,above the softner compatment the two holes will be blocked with black deposits from the water poking a small implement into these holes is probably enough to break up the blockage the softner should then be carried through on the final rinse of the next cycle
