Try this......Down in the right corner, you should see a speaker icon. Right click that, and select Playback devices. Select your speakers from the list, set them as Default, and Click on Apply.
If after that they still do not work, open Control Panel, click on Troubleshooting, and click on Audio devices. Go through that wizard.
SOURCE: NO SOUND
Have you checked on the PC that its not muted.? There is normally an icon at the bottom of the screen which looks like a speaker if you right click on it, it will give an option to open the volume controls. Check this to see if sounds have been muted.
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
