Master
- Posted on Jan 08, 2011
Re: The bar oil will not come out of the reservoir
Oil System Plugged:
- Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution.
- Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out.
- Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability).
- Start the saw and see if it oils when revved up (oozes down side of saw).
- If yes reassemble your saw. If no, continue with 2.
- Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go.
- Carefully check the hoses for cracks especially at bends and connections.
- If equipped with an oil pump it is usually behind the clutch (99.9% of clutches have left handed threads, tighten it to remove it).
- Please make extensive notes & some digital pictures will help during reassembly.
- If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL for the location).
