Question about Logitech Z-2300 2.1 Computer Speaker System (3-Piece)
Alright so somehow I lost my Z-2300 2.1 sound system's wired remote where it controls the volume and bass and I was wondering where I could go to buy a replacement?
Posted by joshdod on
  • Mike
    Mike Nov 11, 2012
    I had almost the same problem as I aquired a Z2300 2.1 with no remote. My solution was to
  • Mike
    Mike Nov 11, 2012
    design and build my own
Mike
    Habit-Forming:
  • 99 Answers
People should read the question before answering!! He has LOST the remote so how can he switch on the power switch on the remote.........
Posted on Nov 01, 2012
3 Related Answers
swimmer33
  • 30 Answers
SOURCE: I set my new Z-2300 but theres no light from the
Make sure both the power switches are on. There is one on the remote and one on the back of the subwoofer just above the power cord. Hope that helps.
Posted on Jan 11, 2011
c_robertson
Computer Doctor
  • 123 Answers
SOURCE: Z-2300 remote does not work
Fist plug it into something other then your computer like a walkman or mp3 player, cd player etc. If it does work then it is the original device (computer I am guessing) If it doesn't work it is the speakers. These models have lost of problems and this appears to be one of them. Some have a sub button on the back of the speaker with turns the sub off seperately.
Posted on Apr 29, 2009
Anonymous
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
I have a wharfedale s21174 and was jst wondering if i can change the base without the remote as i have lost it and the speakers make a slight buzzing sound even without any volume
only if there is a control for it on the back, you can try modifying the equalizer of the source device (mp3 player etc) to create more bass, sometimes they will have a pop or jazz settings which generates more bass, otherwise look for a replacement remote on google
Jun 30, 2011 | Audio Players & Recorders
Only one small speaker is working, it works from left or right outlet, bass isn't working and the other small speaker isn't working. What could be wrong
Your main board located inside the sub woofer that controls and separates the sound
has lost it's ability to switch the sound. You will either have to buy a new speaker system or call the manufacturer to see where a service center for you speaker unit is near you for repair.
This also can be a bad volume control knob either way it will need to be serviced.
Oct 08, 2010 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
To the two people with problems. This sounds a bit odd, but do you still have the broken remotes? I'm looking for a broken one. I'd pay shipping and throw a few bucks your way if you could send it to me.
AIM: gonzoleben
Email: andywitzz [at] gmail [dot] com
Thanks!
-Andrew
Apr 14, 2009 | Logitech Z-2300 Computer Speakers
5.1 surround sound
Here is how you fix it. Its really easy actually take a look at your Subwoofer 99% of the time you can control two controls for your bass somewhere around the Subwoofer. If you raise the volume of your Subwoofer you'll get more bass. Try it and let me know how this works out for you alright.
Oct 03, 2008 | Audio Players & Recorders
Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
Apr 16, 2008 | Car Audio & Video
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Sanyo DWM-2500 Subwoofer bass output
You cannot access the bass settings with the remote. The remote that comes with the DWM-2500 is Sanyo Part #RB-TS760MT
Oct 28, 2007 | Audio Players & Recorders
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Logitech Z-2300 2.1 Computer Speaker System (3-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Vernon Taylor
Lawrence Oravetz
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
