Sony STR-DE345 Receiver Logo
A
Anonymous Posted on Jan 07, 2011
My fuse keeps blowing, what is the problem? - Sony STR-DE345 Receiver
Anonymous
Level 3:
  • Master 675 Answers
  • Posted on Jan 07, 2011
Anonymous
Master
Level 3:
Answers
675
Questions
0
Helped
176328
Points
2146
May be a number of things...the power supply may have a shorted component in it...or the audio output stage may be defective...if you can obtain a volt/ohm meter you can test the power supply diodes and the regulator/audio output transistors...you will need to use the diode check function or the ohm scale to check these semiconductors...they should read infinity in one direction and , on diode test, anywhere from 500-700 for silicon(which is what is used today)..on the ohms scale you should read 500-2000 ohms in one direction and infinity in the other...if you get a 0 reading on any of the semiconductors..then it is shorted and will need to be replaced
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 • Motorcycles
My crank fuse keep blowing what cause it to blow
Ignition Switch / Starter Fuse keeps blowing. - CarGurus
www.cargurus.com > Questions > Ford > Focus
CarGurusAug 14, 2010 - Ignition Switch / Starter Fuse keeps blowing. - I own a 2002 Ford Focus, 2.0l SPI engine. 5-speed manual trans. Recently bought from a friend's ...
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Cop fuse keep blowing on my 2000 lincoln ls
I just got a lincoln ls v8 and fuse #12 cop's is missing what is this fuse for thank you
3answers
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
3answers
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
2answers
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
