Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Won't turn on - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
charles williams
    Novelist:
  • 100 Answers
Hi cbonge,
A battery reset procedure should bring your Ti 84 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Please be prepared to re-install the calculator's OS if you run through this process.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done.
2). Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
reinsert the AAA battery and then turn the calculator on. The calculator should display the
message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator starts responding to key functions your done.
3). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Follow the instructions for the
TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
4). Steps to re-installing the operating system:
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS.
5). Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
6). If the above process did not work. Try re-doing the procedure and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying and follow the procedures.
Posted on Jan 07, 2011
  • charles williams
    charles williams Jan 12, 2011
    You can also get the latest copy of Ti84 Plus 2.55v. MP OS, by going to my link below. Just follow Procedure 1. Plus a lot of other useful information about Ti Connect and, Windows OS.
  • charles williams
    http://www.fixya.com/support/t7769727-ti...
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Jun 17, 2011 | 1999 Ford Windstar
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Won't turn over when trying to start. All dash lights come on...won't stary if jumped.
check the voltage of the battery,, it should be a little over 12 volts,, if not,, replace it
Jun 13, 2011 | 1995 Chevrolet Blazer
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
87 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
