Question about Mitsubishi WD-57833 57" HDTV
White spots all over picture screen. - Mitsubishi WD-57833 57" HDTV
Posted by alnicoman on
Anonymous
    Sergeant:
    Champion:
  • 301 Answers
Optical engine failure. that technology is called DLP digital light processing and it uses a device called a DMD digital micomirror device that has millions of mirrors onthe face and they independtly move and sometimes they can get stuck or not move and cause spots black or white across the entire picture. i suggest calling customer support for possible repair accomodation the cost of the optical engine is around $1100.00+tax plus labor for professional installation part number - 938P075040 phone # for mitsubishi 1(800)332-2119 good luck
Posted on Jan 07, 2011
1 Related Answer
Anonymous
  • 105 Answers
SOURCE: I GET WHITE SPOTS ON MY LCD SCREEN
this is a touchy subject for sony. basically sony has increased the brightness levels for the backlights to have better color tones in thier lcd's. well the downfall of this is the white spots you are experiencing. this is not a defect, you will never get them to go away, the only thing you can do is to turn the backlight and brightness down to reduce the white spots. if you contact sony, there is a software upgrade that will help reduce this issue...
Posted on Oct 25, 2007
Model x1. Why does picture have white spots at the top of the screen?
If the projector is a DLP then it will probably be the DMD chip. The white spots are caused by damaged pixels.
Jan 28, 2016 | InFocus Office Equipment & Supplies
No picture just a blue screen with white over the blue ********* spots on corners of the screen
Bad controller board probably, other makes have this problem too.
If under warranty good, if not bad.
press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 26, 2016 | Olevia LT23HVX 23 in. LCD Television
Mitsubishi hd 1080
It sounds that the panel need replacement.
Jun 22, 2013 | Televison & Video
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Why is my Samsung HL-T5076S is starting to have a small white spot in the picture in the middle of the screen?
1) test the CRT, and Hv rectifier, and flyback.
see the diagram attached.
God bless you
Jul 06, 2012 | Televison & Video
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Spots on screen in front of picture
This could be an issue with your DMD board or your Video Board. Go to the menu, if the white spots show on the menu, the issue is with your DMD board, but if they don't show, the issue is with your Video board.
Dec 07, 2009 | Samsung Televison & Video
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Oct 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WD-57833 57" HDTV Logo
534 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
