Question about Taylor Body Mass Index BMI Scale Black Gray
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
SOURCE: I put the new battery in my Taylor 7004 V1812 and the screen rem
Check and see if you put the battery in right. Make sure the rough part is facing bottom.If this doesn't work your battery may be bad.
Posted on Jul 24, 2009
SOURCE: I have a Taylor body fat analyzer and scale model
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
I got an ERR2 message and now the scale doesn’t work. What should I do?
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Jan 21, 2010
Aug 01, 2014 | Taylor Health & Beauty
Jun 06, 2014 | Taylor & Digital Scale Lithium Scale
Aug 15, 2010 | Taylor & Digital Scale Lithium Scale
Apr 15, 2009 | Taylor 5743 BIA Body Fat Scale
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Oct 29, 2008 | Taylor Chrome & Glass Lithium Digital...
Mar 29, 2009 | Taylor Body Mass Index BMI Scale Black...
283 people viewed this question
