Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
Solution 1 is not helpful, there are no number buttons on a DCP-115C!
