If you have backed up your data (photos, documents, etc.) on an external hard drive, USB disk, DVD's.
If there is company data, or otherwise valuable data, this is better left to a professional! If you are able to cope with the possible loss of all your data, feel free to continue reading.
If you're unable to backup your data, you might try to do so with:
Easeus Data recovery Wizard
Data Recovery Wizard Free 8 6
After you have baked up your data. You could try to recover windows from the error by:
-Pressing F3 repeatedly when the unit is powered on.
-This will get you a menu to load Windows, or Windows recovery
-After this, select "Windows Sytem Recovery Options"
-Follow the on-screen options to try and fix the issue
-If this doesn't work, power on the laptop again and press F3
-load up the Windows option that you are given
!THIS WILL DELETE ALL YOUR PERSONAL DATA AND RESTORE THE COMPUTER TO FACTORY DEFAULTS!
-Select "MSI Recovery Manager"
-IF YOU ARE SURE IT'S OKAY TO LOSE ALL DATA: "OK" > "OK"
-IF F3 Doesn't work, either your recovery files are missing, or your hard disk is failing. If this is the case, you can read on at:
Reinstalling Windows when recovery fails MSI HQ User to User FAQ
Hope this helps!
