if you have combo then start at 0 turn clockways (right) tthree times stopping on first number then counter clockways (left) two times stopping on next number then clockways (right) to last number this should open safe . Good Luck Sorry I may be mistaken on the directions instead of Right,Left,Right do the opposite Left,Right,Left sorry for the mistake. Good Luck
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
As you said that the Right and left buttons are not working as well as the space bar, then it could be the issues with some dust particle inside the keyboard. Try to clean it. Try to use it hope it will work , but in case it don't work then you need to replace the Keyboard.
In case if you have any more trouble do contact back in Fixya. Thank you
I'm going to assume by 'bookmarks' you mean the bookmarks bar. sorry if I'm wrong. >_< There's two ways to get them back: The first way: 1. Go to the upper left hand corner [by 'file', etc] and click on 'View' 2. right after you click on it, under it, it should say 'Toolbars' 3. Once you hover over it, you should click on whichever you need.
The other way: 1. Go above the address bar, and right-click. 2. A menu should appear and then you can click on whichever ones you need back.
The coil packs are numbered 1-4,5-2,3-6.The firing order is 1-6-5-4-3-2.The 1-3-5.cylinders are in front and the 2-4-6 are in the back.There are 2 types of coils.Type 1 the coils are all in one pack.A complete system.Type 2 the coils can be replaced separately.(ie.)1-4 are separate and 2-5 so on.Good luck.
Do you have two controllers? If it's the top left and the top right one that's probably the case. They light up in order top left, top right, bottom left, bottom right based on the number of controllers connected to it
HI, I checked the web site for your bread machine and it is not listed using the numbers you hae supplied. I am including in this post the link to contact the west bend company. They should be able to help you with your product. If there is an actual model number you will want to have that when you call. Best wishes.
1 go to the start menu 2 Right click computer 3 Click manage 4 Go to the storage tab and open it (its in the box on the left side of the screen) 5 Click disk management 6 look for your unusable drive. 7 If the bar is black and it does not say online then you are going to right click the small box on the left side that says "disk X" 8 Pick the 1st option 9 after hitting next a time or two you will have 2 choices to pic from one says something like mass boot or something along them lines do not select that one pick the 2nd option. 10 Hit next till the window closes 11 If the bar is still black right click the black bar 12 Select 1st option 13 Hit next till you see a box that says something like quick format and check that box. 14 Again hit next till its finishes 15 after you finish that the window should show the box with that black bar turn blue and the box on the left will say online.
Sorry i dont have all the terms but i just got help myself and trying to help you all out as well.
