I have OKI B2500 and installed generic toner replacement. Printer asks to install toner card (which came with the toner cartridge). How do I do that? Where does it go? Help. Perry [email protected]
Producers of printers protecting oneself against the mass copying of original toners implemented the number of solutions being aimed at hampering the copying of their solutions. Towards a number of recipes for individual sub-assemblies of the cartridge intended for a laser printer applying special scaling circuits installed in the casing of the toner which are suming the number of printed sides up was the most spectacular solution and are freezing the laser contribution after the achievement of set limit of printouts. Toner do drukarki materiay eksploatacyjne Chip toner co jak
Trata esto: When installing the C3400n printer, or when replacing the toner
cartridge, be sure to fully insert the toner cartridge into the image
drum, and make sure the blue lever is pushed ALL THE WAY toward the back
of the printer (fully locked position). If it is not fully closed
(locked), a "toner sensor" or "toner empty" message may result. Note:
(Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
>> Insure the toner is fully locked, see
photo below showing the correct and incorrect positions of the locked
toner cartridge.
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Does that printer require you to insert a chip?
look in the toner box and see if there was a chip (or a card) that needs to be inserted into the printer.
When installing the C3300 printer, or when replacing the toner
back of the printer (fully locked position). If it is not fully closed
