I have seen a simular fault which ended up being the intermittent wiper relay was full of water from water collected in the airconditoners evaporator tray.
The water has problems escaping this tray & when you go around the corners the water rans out onto your feet & the intermittent wiper relay is mounted down the side of the transmission wall & gets soaked along with the carpet.
I suggest you find the relay, remove it check the inside of it for water damage. If stuffed replace it & also suggest to check your evaporator's tray & rubber S bend drain for obstructions. I think this is a design fault in all 240s.
Another fault I have seen with the wiper motor is it not running too well with excessive noise, due to water getting into the motor through the 2 mounting clips on the round part of the motor casing to the casting. There are 2 small slots which allows water into the motor.
I suggest remove the wiper motor by removing the cir clip & or nut under the dash board connecting to the arms, Then the 3 x 10mm bolts & carefully pull the wiper motor apart don't loose the 2 angled clips & screws, clean & re grease the motor & try not to damage the maganets or over tighten the 2 screws & re assemble in reverse order.
If the windshield wipers on your 2002 Corvette won't shut off, it could indicate a problem with the wiper control switch or a malfunction in the wiper motor circuit. Here are some troubleshooting steps you can try:
Check the wiper control switch: Ensure that the wiper control switch is in the "Off" position. Sometimes, the switch can get stuck or malfunction, causing the wipers to stay on. Try moving the switch back and forth a few times to see if that resolves the issue.
Inspect the wiper motor relay: The wiper motor relay controls the power supply to the wiper motor. If the relay gets stuck or fails, it can cause the wipers to stay on. Locate the wiper motor relay in the fuse box or relay panel and try replacing it with a known working relay of the same type to see if that resolves the issue.
Check the wiper motor circuit: The wiper motor circuit may have a short or an electrical problem that is keeping the wipers engaged. Inspect the wiring harness connected to the wiper motor for any signs of damage or loose connections. Use a multimeter to check for continuity and proper voltage in the circuit. If you are not familiar with automotive electrical systems, it is advisable to consult a professional technician or a qualified electrician.
Disconnect the battery: As a temporary solution, you can disconnect the negative terminal of the car battery to stop the wipers from running. This will disable other electrical components as well, so it's recommended as a temporary measure until the issue can be properly diagnosed and repaired.
Wiper/Washer System Components
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor
• Windshield wiper motor module
• Windshield wiper/washer switch
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Wiper/Washer System Operation
The windshield wiper motor module is part of the windshield wiper motor cover and controls wiper motor operation. The accessory voltage supply circuit to the windshield wiper motor assembly is used to operate the wiper motor in all modes. The windshield wiper motor is a 2 speed motor and is operated at low speed in all modes except HIGH. The accessory voltage supply circuit to the windshield wiper/washer switch is used to supply the windshield wiper switch signal circuits. The windshield wiper switch signal circuit voltage levels to the wiper motor module determine the wiper motor operating mode.
When the wiper/washer switch is in the LOW position voltage is supplied through a 24K ohm resistor within the switch to the windshield wiper switch signal 2 circuit, and accessory voltage is supplied to the windshield wiper switch signal 1 circuit. The reduced voltage from the wiper switch signal 2 circuit and accessory voltage from the wiper switch signal 1 circuit causes the wiper motor module to close the wiper motor accessory voltage supply circuit to the wiper motor low speed terminal.
Do you know how to test automotive electrical circuit's using a DVOM - digital volt ohmmeter ? Do you know what a wiring diagram is an how to read one ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on body & accessories ,then under subsystem click on wiper/ washer's . Click the search button then the blue link.
Windshield Wiper/Washer System Components
The windshield wiper/washer system consists of the following components:
• Windshield washer relay
• Outside moisture sensor
• FRT WIPER 25A fuse
• W/S WASH 15A fuse
Windshield Wiper/Washer System Operation
Accessory voltage and ground is supplied to the windshield wiper motor and provides the power for operating the wiper motor and logic power to the wiper motor module. The WASH, MIST, LOW, and DELAY modes are controlled by the windshield wiper/washer switch through a series of internal resistors. The windshield wiper switch supply voltage circuit is a 12-volt reference from the wiper motor module to the wiper/washer switch, and the switch position determines the point on the resistor assembly where the reference voltage is applied. The windshield wiper switch signal 1 circuit supplies the voltage from the resistor assembly to the wiper motor module and the signal voltage determines the operating mode. High speed operation is controlled by the windshield wiper/washer switch through the windshield wiper switch high signal circuit. The windshield wiper switch high signal circuit is supplied 12 volts by the wiper motor module and when the wiper/washer switch is turned to the HIGH position the windshield wiper switch high signal circuit is grounded through the switch ground circuit. The windshield washer pump is controlled through the windshield wash relay. The windshield wash relay coil and switch is supplied battery positive voltage, and during WASH mode the wiper motor module grounds the washer relay control circuit energizing the relay. When the relay is energized battery positive voltage to the switch side of the relay is supplied to the washer pump control circuit.
Did you check the wiper relay's in the under hood fuse box ? There are two ,wiper run/park relay & wiper high low relay ! Also ,did you check fuse's ? fuse # 11 - 30amp location cental juction box . The wiper switch is a input to the GEM module . Generic electronic module . The module in most cases isn't the problem ! Learning how to test these electronic systems is , people do not know how to test so they just replace parts . What they should do is take the vehicle to ford certified Technician who has the knowledge and testing equipment to find an fix it .
The generic electronic module (GEM) receives inputs from the following:
multifunction switch
anti-lock brake control module (vehicle speed signal [VSS])
ignition switch
The GEM uses these inputs to control the outputs to the following:
windshield wiper high/low relay
windshield wiper run/park relay
windshield washer relay
rear wiper motor relay
rear window washer relay
GEM Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1240
Wiper Washer Rear Pump Relay Circuit Failure
GEM
GO to Pinpoint Test K .
B1241
Wiper Washer Rear Pump Relay Circuit Short to Battery +
GEM
B1342
ECU is Defective
GEM
CLEAR the DTCs. REPEAT the GEM self-test. If DTC B1342 is retrieved, INSTALL a new GEM. REFER to Section 419-10 .
B1431
Wiper Brake/Run Relay Circuit Failure
GEM
If the windshield wipers are inoperative, GO to Pinpoint Test B .
If the windshield wipers stay on continuously, GO to Pinpoint Test C .
B1432
Wiper Brake/Run Relay Circuit Short to Battery
GEM
B1434
Wiper Hi/Low Speed Relay Coil Circuit Failure
GEM
GO to Pinpoint Test D .
B1436
Wiper Hi/Low Speed Relay Coil Circuit Short to Battery
GEM
B1438
Wiper Mode Select Switch Circuit Failure
GEM
If both the windshield and rear window wipers are inoperative, GO to Pinpoint Test L .
B1441
Wiper Mode Select Switch Circuit Short to Ground
GEM
B1446
Wiper Park Sense Circuit Failure
GEM
If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
If the speed dependent interval mode does not operate correctly, GO to Pinpoint Test G .
If both windshield and rear wipers are inoperative, GO to Pinpoint Test L .
B1450
Wiper Wash/Delay Switch Circuit Failure
GEM
If the wash and wipe function does not operate correctly, GO to Pinpoint Test F .
If both the windshield and rear wipers are inoperative, GO to Pinpoint Test L .
B1453
Wiper Wash/Delay Switch Circuit Short to Ground
GEM
B1458
Wiper Washer Pump Motor Relay Circuit Failure
GEM
B1460
Wiper Washer Pump Motor Relay Coil Circuit Short to Battery
GEM
B1473
Wiper Low Speed Circuit Motor Failure
GEM
If the windshield wipers do not operate at high or low speed correctly, GO to Pinpoint Test D .
B1475
Accessory Delay Relay Contact Short to Battery
GEM
REFER to Section 501-11 .
B1476
Wiper High Speed Circuit Motor Failure
GEM
If the intermittent windshield wiper does not operate correctly, GO to Pinpoint Test E .
B1611
Rear Wiper Mode Switch Circuit Failure
GEM
GO to Pinpoint Test H .
B1614
Rear Wiper Mode Switch Circuit Short to Ground
GEM
GO to Pinpoint Test I .
B1820
Rear Wiper Motor Up Relay Circuit Short to Battery +
GEM
B1839
Rear Wiper Motor Circuit Failure
GEM
All other DTCs.
GEM
In the under hood fuse box , should have diagram inside the lid . Front wiper's or rear ? Front fuse # 36 - 25 amp. Plus Two relay's PCB hi and Wiper PCB relay . Wouldn't think this being fuse problem . Wiper switch , motor etc... The wiper's are control by a computer . BCM - body control module .
The windshield wiper/washer system consists of front and rear wipers. The front and rear wipers are operative when the vehicle is in accessory or run. The front wipers have 4 different modes: Mist, Intermittent, Low, and High. When the front wipers are in the intermittent mode, there are 5 delay modes to chose from, commanded by the windshield wiper washer switch through the body control module (BCM). The rear wipers has an only one mode.
If the fuse is bad , could have a short to ground or wiper motor pulling to much current (amps) . Fuse's don't just blow for no reason ! Could also have DTC'S - diagnostic trouble codes stored in the BCM .
DTC B3715
DTC B3873
DTC B3875
DTC B3922
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two different PCB relays which control the desired wiper speed, high or low.
DTC B3922 00: Front Wiper Function Select Circuit
The PCB relay's are non- servicable , replace fuse box . Soldered in Your best bet mit be to take it to a qualified repair shop .
First you need a wiring diagram, free at http://www.bbbind.com/free_tsb.html Then you need a DVOM - digital volt ohm meter to test the circuit . Then if your not familiar with automotive electrical systems testing ,go on youtube an check out Electric Testing Techniques You Need to Know Also having a factory diagnostic trouble shooting chart would also be usefull . You could just start replacing parts , you mite get lucky . The wiper motor is a high fail part , so is the switch ..You could find the fuse is blown ! But fuse's don't usually blow without a reason . Short to ground , low resistance . ( high current flow) Also knowing how they work and what all is involved in making them work.
The Wiper/Washer System consists of the following components:
• FRT/WPR/WSHR 25A fuse
The windshield wiper motor module is part of the windshield wiper motor cover and controls wiper motor operation. The windshield wiper motor is a 2 speed motor and is operated at low speed in all modes except HIGH. The accessory voltage supply circuit to the windshield wiper motor assembly is used to operate the wiper motor in all of the low speed modes. The accessory voltage supply circuit to the windshield wiper/washer switch is used to supply the windshield wiper switch signal circuits and the wiper motor high speed circuit.
Windshield wiper/washer system MIST operation is identical to LOW operation except that the MIST switch is a press and release type. When the wiper switch is moved to the MIST position and released, low speed wiper motor operation is started and will continue until 1 cycle is complete. If the wiper switch is moved to the MIST position and held, the windshield wiper motor will operate in the LOW mode until the switch is released.
Don't the wipers work in any mode ?
Did you review the Wiper/Washer System description and operation and perform the necessary inspections?
YES - Go to Step 2
NO - Go to Symptoms - Wiper/Washer Systems
Turn ON the ignition , with the engine OFF.
Operate the windshield wiper/washer switch through all the switch positions.
Does the windshield wiper/washer system operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Turn OFF the ignition.
Disconnect the harness connector of the windshield wiper motor.
Turn the ignition ON, with the engine OFF.
Connect a test lamp from the accessory voltage circuit of the windshield wiper motor to a good ground.
Does the test lamp illuminate?
YES - Go to Step 4
NO - Go to Step 13
Connect a test lamp from the accessory voltage circuit to the ground circuit of the windshield wiper motor.
YES - Go to Step 5
NO - Go to Step 14
5
Connect a test lamp from the signal 2 circuit of the windshield wiper switch to a good ground.
Press the windshield washer switch.
YES - Go to Step 11
NO - Go to Step 6
Let me know if you make it this far and i will send rest of diagnostic's
There are three things involved in wiper operation, switch, the delay circuit board and the motor. If you select winshield wash do the wipers operate normaly? if this is the case then the motor works and delay is operating < not a guaranty on delay but it does say the circuit is operating.If wash cycle does not work then circuit not working< could still be switch causing this> if you know someone or you yourself can remove switch it needs to be ohmed to know that it is operating and if it is then voltage during operation in all settings needs checked at wiper motor.If no voltage found in inoperable settings then delay is not working.While investigating problems like this always inspect wiring as you check from point to point because could be damaged wires as well.
