Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while opening the scanner Please check the scanners status and the scanner connection Error code 2106" From what I've seen online I tried the SSE utility but was greeted with another message saying "your processor supports SSE this utility will not help you" My computer fully recognizes my printer and the connection is solid, Also fully un-installed all software and re-installed a couple times. Everything installs fine. No error and everything is ready to use....so yeah What exactly is wrong with my printer?
Posted by seth_moser on
  • Kodak Master
  • 6,414 Answers
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Posted on Jan 06, 2011
2answers
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
2helpful
2answers
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
I CANT OPEN KODAK AIO HOME CENTRE SOFTWARE FROM MY WINDOW 7 MY PRINTER IS KODAK ESP 3250 PLESE HELP WHAT I DO?
I want to print passport photos on my EasyShare 3250 All-in-One Inkjet Printer, how do I do it?
36helpful
5answers
Kodak esp 5 won't scan to computer...please note spammers number below
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
3helpful
2answers
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
