Question about Akai PT4298HD Rear Projection Television
Volume won't lower and can't change to av anything univesale remote won't work after programming it the day before!
Posted by robrossetter on
Anonymous
    New Friend:
  • 55 Answers
Most likely the remote is not compatible with the Akai TV you have. Does it work correctly with the original remote?
Posted on Jan 06, 2011
On mx900 genesis universal remote the up down arrows to change channels will not work - cannot get guide to display -cannot change channels using#key pad - volume up down work fine suggestions?
Incorrect code. Try different programming codes for one that operates your TV correctly. Note not all universal remotes will work all features of a tv. Sometimes all you can get (especially on lower end remotes) is power and volume
Nov 01, 2016 | Televison & Video
Lost remote for tv.can it work without?
Without the remote, you should be able to perform basic tasks, such as:
-change volume level
-change progamme
-turn the tv on/off
-possibly access AV or other inputs
if your tv has a MENU button on it, then you will be able to perform more complex tasks and you may even be able to tune it in etc.
Alternatively, you can purchase a universal remote control that can be programmed to use with your tv.
Aug 27, 2011 | Televison & Video
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
MY CONTROLLER WILL NOT CHANGE PROGRAM OR ADJUST VOLUME
Carefully open the remote controller unit and look inside for possible failure of the carbon pads or the remote control PCB tracks.So first of all open to clean the padds and the pcb then check specially on the volume controller pads, use old pads to be stuck on or carbon dots that are available for repairing remote controllers.Repeat this for the program pads. If the fault does not clear then look into the PCB section of the volume tracks and program tracks and use a carbon pen to make the tracks prominent. Hope this works. Good day
Aug 11, 2010 | Bose Wave Music System Remote
My dish network remote control powers the receiver (turns it on and off), but it won't change channels or adjust the volume. why?
I hope that your remote is working now, but if it is not, or you have any other issues in the future, here are some steps to help out. The link below will walk you through programming both your remote to the volume and the receiver. Sometimes the remote will not work certain functions if the batteries are starting to ware out, also if there is anything blocking the dish, the remote doesn't work as well. So you will want to make sure that there is nothing in front of the receiver, such as glass, and that your batteries are less than 60 days old.
Steps 1-5 are for the receiver, and 6 on are for the tv! I hope this helps!!! http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
Jul 30, 2010 | DISH Network IR Remote Control
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Remote Volume Control Not Working
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Jan 05, 2008 | Sony STR-DA3ES Receiver
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Aug 20, 2007 | Broksonic CTGV-5463TCT TV
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Akai PT4298HD Rear Projection Television Logo
47 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
