Question about Proform CrossTrainer Treadmill
Need to oil - Proform CrossTrainer Treadmill
Posted by ft11946 on
Paul Sikkema
    Novelist:
  • 171 Answers
No, you don't need to oil or lube this treadmill. If the belt is squeaking get a bottle of treadmill lubricant and apply a small amount.
If the arms are squeaking a small shot of silicone spray will quiet them down.
Posted on Jan 06, 2011
I need to replace the oil sender switch on my 2002 Buick La Sabre
first need to buy oil pressure sending unit 3/8 deep socket remove oil pressure sending unit you need teflon tap sealer for oil sending unit threads.okay to replace oil pressure sending unit.you need safe raise support vechicle locate oil pressure sending unit next to the oil filter.disconnect oil pressure sending unit wire connector then use oil pressure sending unit 3/8 socket remove the sending unit.then take new oil pressure sending unit use teflon tape white plumbers tape or use thread sealer apply to the oil pressure sending unit threads then install new oil pressure sending unit and reconnect electrical connector to sending unit.then crank engine check for oil leak if all is good lower vechicle back to ground wait several minutes check engine oil level.you good to roll.
Feb 09, 2013 | 2002 Buick LeSabre
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
My oil light is flashing red and making a dinging noise
Could just be out of oil. Check the oil. Don't drive it! If it has plenty of oil the oil sending unit maybe faulty.. Best have a shop check engine oil pressure with a mechanical oil pressure gauge before driving it.. Engine will be ruined if you drive it with no oil pressure.
Sep 16, 2011 | 2005 Buick LaCrosse
Why is oil light blinking?
Oil light blinking usually indicated low oil pressure / viscosity. Probably either low on oil, incorrect oil weight, poor quality oil, or needs oil changed..........Mike
Jun 19, 2011 | 2002 Mercury Sable
Hi. I have 2007 Mercedes GL450 , Can you help me with oil change and oil filter change.Please tell me How to do it properly? The nearest Mercedes service is over 500 km. thanks alot, A
BEST TO LET DEALERSHIP CHANGE ENGINE OIL.YOU NEED A DEALERSHIP OIL FILTER.YOUR OIL FILTER INSIDE A HOUSING ON FRONT SIDE OF THE ENGINE. CHANGING YOUR OWN OIL NOT HARD.YOU NEED 9 QUARTS OF OIL LOOK INSIDE GLOVECOMPARTMENT FOR OWNERS MANUAL TO SEE WHAT TYPE OF ENGINE OIL YOU NEED TO USE AND HOW MANY QUARTS.IF YOU DONT CHECK READ MANUAL TO SEE WHAT OIL TYPE AND QUARTS YOU NEED. IF YOU BLOW OR DAMAGE THE ENGINE WARRANTY WILL NOT COVER THE ENGINE.FIRST OF ALL TO CHANGE ENGINE OIL YOU CRANK VECHICLE UP LET IDLE FEW MINUTES TO THIN OUT OIL THEN YOU TURN OFF ENGINE. YOU NEED TO RAISE VECHICLE USING THE FACTORY JACK.USE JACK STANDS. LOOK IN OWNERS FOR CAR JACK LIFTING LOCATIONS TO KEEP FROM DAMAGING ROCKER PANELS. AND PLACE A DRAIN PAN UNDER THE OIL PAN. UNDER THE VECHICLE.YOU NEED A WRENCH TO REMOVE OIL PAN DRAIN PLUG.WHEN ALL THE OLD OIL DRAIN OUT IN THE DRAIN PAN.SCREW BACK IN THE DRAIN PLUG TIGHTEN IT DONT OVER TIGHTEN STRIP THREADS.THEN YOU NEED SOCKET TYPE OIL WRENCH YOU USE WITH A 3/8 RATCHET WRENCH REMOVE OIL FILTER HOUSING.PLACE RAGS AROUND THE OIL FILTER HOUSING TO CATCH OIL SPILL. YOU WILL NEED TO GO TO THE DEALERSHIP FOR THE OIL FILTER AND FILTER HOUSING O RINGS. ONCE YOU GET NEW OIL FILTER AND O - RINGS INSTALL THEM IN THE OIL FILTER HOUSING.LOCATED OIL FILLER CAP ON VALVE COVER UNDER THE HOOD.REMOVE OIL FILLER CAP.POUR OIL IN ENGINE USING A FUNNEL.ENGINE HOLDS ABOUT 8.5 TO 9.0 QUARTS OIL. BUT LOOK IN THE OWNERS MANUAL CHECK HOW MANY QUARTS ENGINE NEED.CHECK OIL DIP STICK OIL LEVEL SHOULD BE ON THE FULL MARK ON THE ENGINE OIL DIP STICK.TO BE ON THE SAFE SIDE BUY 10 QUARTS OF OIL FOR A EXTRA.DONT OVER FILL MAKE SURE YOUR OIL LEVEL CORRECT.OIL DRAIN PLUG AND OIL FILTER TIGHT BEFORE CRANKING THE ENGINE.LOOK IN THE OWNERS MANUAL FOR OIL DIP STICK AND LOCATION.
Nov 05, 2010 | 2007 Mercedes-Benz Mercedes Benz Gl 450
Try to replace oil but could not find a oil plug where is oil plug of CLK55 AMG
IF your car CLK 55 AMG it's better to get your car in to the dealer for service because it's need much knowledge to replace oil in this particular car, and must get the right oil for it, it's very particular oil need to fill in to the engine, must use Mobil 0W-40 fully synthetic oil and also need to drain oil from oil cooler and need to **** oil in side the filter housing, drain plug is under oil pan. my advice is get in to the dealer, it's up to you. is this information helped you?
Nov 02, 2010 | 2004 Mercedes-Benz CLK-Class
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
Mx5 mk2.5 slight engine oil leak.
Can you tell us more?
How many miles on the car?
Which side of the engine area? Drips after you park etc?
Oil ever low? If so how often do you ad oil?
Any visible oil on engine and bay components under hood?
likely areas for oil leaks may include depending on model and make:
Oil pan gasket seal.
Oil pressure sending unit.
Oil filter installed dry or over tightened at your last oil change.
Oil drain plug loose or plug gasket needs replacing.
Valve cover gasket needs replacing.
Crank shaft seals need replacing.
Distributor seals need replacing.
RTV gasket sealer beyond expected life and need replacing for other engine components, inspection plates or covers.
Sep 21, 2009 | 2002 Mazda Miata
My oil light is on, i have 39 miles on my gsxr 600. do i need an oil change or do i need to put oil in
Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
Sep 18, 2009 | 2008 Suzuki GSX-R 600
Need instructions for doing an oil change.
For doing on oil charge need to waste oilbasin ,new oil filter ,new oil canister.After that you need to run genine whith oil cleaner atleast 10 minutes,after wentilaiting ,stop the engine ,open drain plug and drain derty oil in waste oil basin,close drain plug, replase old oil filter ,fill in new oil.
Aug 09, 2009 | 2005 Mazda Tribute
Proform CrossTrainer Treadmill Logo
1,068 people viewed this question
Top Proform Exercise & Fitness Experts
Marvin
Marvin
john h
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
