Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
