The volume control assembly probably has dirt/dust built up inside...you can clean the control with an electrical contact cleaner that is safe on plastics (ask your retailer ). You will need to remove the cover to gain access to the volume control assembly. Once the cover is removed you can spray the cleaner into the control assembly. Whilst your in there you may want to clean any other controls. Make sure you let the cleaning agent dry thoroughly before you power the unit back up. Another possibility is (if the above dosen't solve it) the control itself has become defective and will need to be replaced
