Expert
- Posted on Mar 07, 2011
Re: Cant load roxio 2011 code error oood plaese tell me...
Please refer to the steps below and follow it carefully as it will help you resolving the problem.
- Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
- Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
- Select the Startup tab.
- Click the Disable All button.
- Click the Apply button, then click the OK button.
- Click the Restart button.
To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
- If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
- Create a new folder on your Desktop.
- Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
- Select ALL of the files in the installer window and copy to the folder you just created.
- To install from the folder, double click the setup.exe file.
- If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
- Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
- Go to Edit -> Select All.
- Go to File -> Delete.
- Reinstall software
