Crosley Radio Pictograph Slide Negative Scanner 1 ea Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do you scan to? Do you scan to a memory card? Do you scan to a CD?
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Jan 05, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
54396
Points
471
Flash drive or right to computer any ting with usb port
2answers
How to scan memory card?
Try connecting your phone to the computer via usb cable if your phone is capable of that and click your phone icon once it appear on the computer and left click on your phone and look for scan on the menu. Then your phone will be scanned. The other way is by taking off your memory card out in your phone and inserting it to a laptop and scanning it manually. Usually a micro sd are the memory cards thats being used on phones so you should have an adaptor for you to be able to insert it into your laptops SD card slot.Hope this helped you in anyway..have a nice day.!!!!
Mar 26, 2012 • Cell Phones
2helpful
Nokia N70 Memory Card show Memory Card Corrupted in Phone And my coumputer.
If your memory card is showing memory card corrupted both on the phone and your computer, then it means there is a problem with the memory card. Most likely the memory card would have been corrupted by a virus.
What You will have to do is to try to run an anti virus scan on the memory card. To do so, when You connect the memory card to the phone, You will have to right click on the memory card, then select scan using the anti virus of Your choice. Then it will scan the memory card and wipe out all corrupted files and viruses.
After doing so You can format the memory card before using it again.
If it does not work, then it means the memory card is damaged beyond repairs.
Hope this helped.
Thank You for using FixYa.
14helpful
3answers
Hi, I use a 4GB memory card for my nokia C3 but from time to time my phone just gets hung over & dies. Then when I switch it back on without the memory card it works & when I try putting back the...
Hello Divinegoddes,
It seems that your phone memory card contains the virus.So scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the above link.
Install the software in your computer. Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
91helpful
2answers
Phone virus
Hello Leopard,
Download the .exe file from the link.
3helpful
2answers
Some times my N 70 nokia hanging
Hello Anilpillai,
2helpful
I inserted my memory card into my mobile phone but it says 'bad format' what can i do
or
The memory card contains the bad sectors.
HP Photosmart 2575 All-In-One, "memory card error", can not scan, only print. Please help!!
Hello, please try the "HP image zone" software that you can install form the CD included in the printers box, in order to scan. About the memory card, have you plugged a memory card to the printer?
1helpful
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
2helpful
2answers
Virus on cell phone memory card
1. you can remove the memory card from your phone connect it to a card reader and format the memory card or scan for virus.
1. If you have a compatible cable to conect to PC then you can connect your phone is memory card mode (mass storage or data transfer mode) and then scan for virus. if the virus are detected from the anitvirus it's good else i would suggest you to format your memory card.
Mar 28, 2009 • Cell Phones
Top Crosley Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
