The Microsoft Visual C++ 2005 Redistributable Package (x86) installs
runtime components of Visual C++ Libraries required to run applications
developed with Visual C++ on a computer that does not have Visual C++
2005 installed.
This package installs runtime components of C
Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For
libraries that support side-by-side deployment model (CRT, SCL, ATL,
MFC, OpenMP) they are installed into the native assembly cache, also
called WinSxS folder, on versions of Windows operating system that
support side-by-side assemblies.
System Requirements
oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
File Name:
Size:
vcredist_x86.exe
2.6MB
Download
Dear,
Mostly, this kinds of error can be caused by two factors:
1.Runtime components of Visual C++ Libraries are missing.
2.Software problem.
If the issue is caused by #1, you can reinstall the Runtime components of Visual C++ Libraries to resolve the problem.
Microsoft Visual C++ 2008 Redistributable Package (x86)
http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
If
the issue still persists after installing above package, the issue
should be a software problem. I suggest you take a clean boot check
whether it is a software conflict issue. If not, it is still recommended
to address the problem with manufacturer support. Thank you for your
understanding.
For your convenience:
Clean Boot
1.
Click Start, type "MSCONFIG" (without the quotations) in the Search Bar
and Press "Enter" to start the System Configuration Utility.
2. Click the "Services" tab, check the "Hide All Microsoft Services" box and click "Disable All" (if it is not gray).
3. Click the "Startup" tab, click "Disable All" and click "OK".
4. Restart the computer and test the issue.
Note:
Clean Boot is a troubleshooting step. If some programs have been
disabled, we can re-enable them later. If you see the System
Configuration Utility, check the box of "Don't show this message" and
then click "OK".
Please
monitor the system in the Clean Boot environment. If the problem does
not occur, it indicates that the problem is related to one application
or service we have disabled. You may use the MSCONFIG tool again to
re-enable the disabled item one by one to find out the culprit.
Best of luck!
