SOURCE: Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
SOURCE: Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
SOURCE: Temperature Control
we have a similar problem with an AFG 7080 model, with inability to control the temperature
how and where do we find the condensor and how do we get hold of the right manual?
SOURCE: deluxe electronic control alarm on
I would first look at why the alarm is going off without disconnecting it, you could have a seal issue with the freezer in which the door is not closeing properly or you could also have a defrost issue with the unit which would also trigger the alarm Diagnoseing what the issue is is the first thing that should be done not just unplugging the alarm and ignoreing there is an actual problem most of the time when these issues are ignored you end up paying for it in the long run. I would look further into why you are getting the alarm I await your reply if you have any further questions Thanks Rick
