SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
SOURCE: Krups type 889 Espresso machine leaks water
I have found the two parts mentioned in my previous Email on a webpage other than yours, however I have not ordered the parts at this time. If you have the parts in stock, let me know the price.
Once I receive the parts and replace them, I will know for sure if my troubleshooting is correct.
SOURCE: water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
SOURCE: how to use krups espresso machine
The metal nozzle under the rubber frother is plugged up. You can remove it with a wrench (it is threaded). I now wash mine after every use since mine plugged so badly I had to use wire to unplug it. Milk does that.
